Question about Philips 60P8341 60" Rear Projection Television
Philips 60pp9202/17f convergence problem
I want to replace the IC chips
  • 728 Answers
In order to do this you have to be very good with technology and you have to know what you are doing because if you slip up once, you make a mistake and touch a part that holds a charge even after unplugged and you may get shocked. This would be best done by a professional so that it will be completely correct and the chance of danger will be lower.
Posted on Mar 08, 2009
    Genius:
  • 1,550 Answers
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
http://www.electronix.com/catalog/default.php/cPath/6
You need to replace both convergence ICs .It will cost you around $30 .
The IC Is STK .
2 Suggested Answers
SOURCE: Philips TV model 60PP9202/17F veins circuit board destroyed
philips tv model#60PP9202/17F has blue shadows, do i need to adj color or something?
Posted on Mar 06, 2010
My red convergence won't move side to side only up and down what do i do? the blue moves up down and side to side, i noticed this when the picture as we were watching it decided to turn 3d, so i tried to...
Most of these Philips sets use two STK-392-120 convergence IC chips; if you can locate them inside look at all the little blue resistors to the left and front of them---these are feedback (protect) parts---if any of them are discolored in the middle--not powder blue but somewhat white in the middle---you have a bad ic and both need to be replaced---most of the protect resistors are 6.8 ohm in value. If this has been helpful give me a vote.
Aug 14, 2009 | Philips 60PW9363 60" Rear Projection...
Convergence bad
resistor along the convergence are 2Watt size or less. they are easy to find as all of them are in pairs. if you find one is not the same on the other, then replace that resistor. change the 2 convergence IC at the same time. let us know.
Mar 22, 2009 | Philips 43P8341 43" Rear Projection...
Where to buy the convergence board of a 55PP9502
You can find a replacement auto convergence board for a model # 55PP9502 from this major Philips part distributor at the following link:
Philips 55PP9502 Replacement Part Auto Convergence Board
Feb 02, 2009 | Philips 55PP9502 55" Rear Projection...
Convergence problem with Philips 60PP9352
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Oct 01, 2008 | Philips 60PP9352 60" Rear Projection...
60PP9352 60 in. Rear - Blue convergence issue
Replacing only the ICs MAY solve the problem, however, many people have also had blown resistors requiring replacement. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice.
You do not have to replace any transistors to fix this convergence failure.
May 28, 2008 | Philips 60PP9352 60" Rear Projection...
Convergence
i have tried this replacement on philips 43 inch. convergence ic part # is STK-392-120. it is mounted on a big heatsink, replace this 2 IC at one time. soldering is not difficult. 1. you need desoldering tool (**** type) 2. soldering iron of 40W 3. and silicon grease for greater transfer between IC body and heatsink. i bought that personally in asia for less than 50USD on two IC with same part # . let me know if there is any other thing i can do.
Apr 02, 2008 | Mitsubishi WS-65869 65" Rear Projection...
Converge problem
That sucks. I just did my convergence and now I am having mixed colors that I have to adjust. Sucks, Good luck!
Mar 29, 2008 | Philips 60PP9202 60" Rear Projection...
Auto convergence
Bull!!!!!!!!! i dont think he knows what hes doing....
you can send the board into ptscorp.com have them check it out, it's the board with big black iC stk392-XXX send that one in, you convergence is done thru the menu system.
Feb 15, 2008 | Philips 55PW9363 55" Rear Projection...
Convergence /ic chips
I just did it myself and it ran about $80. Make sure you get the IC's (2) and I would replace the 12 resistors.
Jan 09, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60P8341 60" Rear Projection Television Logo
27 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
