Question about SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW)
No power I have my frame connected to my computer and the usb port is okay. It is turned on, but no power.
    Problem Solver:
  • 11 Answers
You have to plug it into the wall for power. It does not get power from the USB port.
Posted on Jun 26, 2009
Kenwood amp kac 7495
GND is for a ground wire, run from frame of amp to frame of computer, and frame of UPS unit. I presume UPS means Uninterpretable Power Supply, a battery power backup. If you mean USB, the wire that accessories to the computer use, I doubt it. If it does have an USB port, it should be ok to check it out.
Dec 01, 2013 | Car Audio & Video
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
How do i download photos from pc to digital photo frame
1. Connect the digital photo frame to an available USB port on the PC. Turn on the PC and the digital photo frame. Connect one end of the USB cable to the USB port on the digital photo frame (this end is usually smaller) and connect the other end to the USB port on the PC itself.
2. Wait for the PC to automatically detect the USB-connected digital photo frame.
3. Move any photo files that you want to display on the digital photo frame. Do so by copying and pasting each file into the connected USB device that you can view in "my computer". Many photo frames have built-in memory for this feature.
Jan 07, 2011 | Microsoft Computers & Internet
Front usb ports are no longer working after I plugged in an external 2.5" SATA drive. The computer automatically powered off and I had to reboot. Now when I plug in even a flash drive nothing happens....
Hello
The connector of front panel may gone disconnected, you need to check the connector inside the compute and re-connect it properly.
Hope it helps, do rate the solution if so
Dec 26, 2010 | MSI 7529-050R Motherboard
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
I am having trouble connecting my SP 104 WM to the
Where can I find a remote control for my Smartparts digital picture frame SP104C?
Nov 19, 2009 | SmartParts SP104MW Digital Picture Frame
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
I cant figure out how to download pictures onto the frame from my pc
Connect the frame to the pc. Look in my computer - it will be a device with removable storage. - drag and drop pics or a whole folder of them to the frame.
If the PC isnt picking up the frame at all... try a USB port in the back of the computer. Also make sure the frame is powered on!
Dec 10, 2008 | PANDIGITAL (DPF802) Digital Picture Frame
How Do You Open the USB port
Look in "My Computer" or "Windows Explorer" the device may show up as a drive or connected device.
Nov 19, 2008 | Warrior 797146022002
Download mp3 music
Power ON the frame.
Now you can play.
Good Luck.
Live, Love, Laugh.
May 12, 2008 | Audio Players & Recorders
SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW) Logo
181 people viewed this question
Top SmartParts Photography Experts
Tony
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
