Question about Garmin GPS
Webupdater won't detect Garmin unit
I have a Garmin Nuvi 850 with preloaded North American Maps and I have also loaded New Zealand maps. I have a guarantee update for the NZ maps to the 2009 version but I am getting a "there is a problem communicating with your Garmin device error". I am running XP pro.
I'm unable to do a firmware update as WebUpdater says it can not find the device after I have connected it using USB. I get the following error message: "Some devices were found; however, none have the necessary capabilities. Please make sure your device is connected to the computer and turned on, then try again. You may also need to set interface option on your GPS to "Garmin" or "host"."
How do I get the WebUpdater to detect the GPS unit?
Thanks
I have the same problem of the Nuvi 850 being recognized by webupdater. I downloaded 4.30 firmware update using this link http://www8.garmin.com/support/download_details.jsp?id=4043 plug the unit in and ran the update. It will ask you to disconnect once it is done. The unit will boot up after a few update progress bars. Plug it back in and launch webupdater.
Enjoy,
Fellow 850 owner.
Posted on Mar 26, 2009
The below solution that I found on another site worked for me. Good luck!
Look at the programs you have running in the background. Some of those like printers or PDA interface software will hog the COM1/Serial port. I just looked at my task bar on the bottom right of the screen, and right click and turned off my printer software and a few other things. Then my GPS would link up properly and update with the Garmin Updater. I don't get why all the other forums have complicated explination that only help a small precentage. This solution will help over half of the problems.
Posted on Mar 24, 2009
I lost all my maps on my Garmin Street Pilot C330. I contacted Garmin support and went through a number of steps with them including a master reste to no avail. My unot was not being detected on their website and I couldn't register it or access "My maps". All the while I was trying to fix this I was indoors at my desktop where my unit would lose satellite reception. I took my laptop computer and unit outdoors where I got satellite reception. Loaded the Garmin USB drivers and Communicator program on my laptop. Turned on the unit, let it attain satellite reception, plugged it into the computer w/ USB cable and bingo! The unit was detected by the Garmin website. I was then able to register and access My Maps. I downloaded my maps to the unit, which in all took about an hour to complete. Problem solved.
Posted on May 18, 2012
I bought this devise in USA last year where it worked very well.I fished it out the other day but it doesn't work here why?
When you mean does not work, does the unit power up or is it plain dead? If it does not turn on, then you will need to troubleshoot or send out for repair.
If it turns on, but does not provide you with maps, you need to load maps for Australia as you currently have US maps loaded on the device.
Google search for Australia maps for your unit, or contact Garmin customer service.
Mar 26, 2015 | Garmin nuvi 1350 Car GPS Receiver
Garmin nuvi 3760. I have downloaded North american maps to the SD card but the Nuvii doesn't recognise the SD chip map when I go to tool, maps etc. Help
Update your unit using Garmin Webupdater. The latest updated firmware allows the units to read all sd/microsd cards You can download garmin webupdater from here: http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Download install and run the program and follow the on screen prompts to update your unit.
Sep 27, 2011 | Garmin Nuvi 3790T 3790 3760T 3760 3750...
My gps is set on peru and i am in the us, the gps can not find the maps of us. thx ziv
You'll have to load the North American maps into the unit. Go to www.garmin.com and register your unit with the site. You will then be able to purchase the north american maps and download to your unit using the Garmin updater on the site. The maps are all serialized to work with each unit ID, so a North American map on another user's Garmin will not work on yours (it is Garmin's proprietary copy protection system).
May 23, 2011 | Garmin nuvi 250W GPS Receiver
Where do i find seriual number? how do i register my gps ? and how do i downdload 2011 maps?
depends on your unit... The Nuvi serial number is on the bottom of unit where it connects to the cradle to mount, Garmin also puts a number sticker on the Box your Nuvi came in.
you must first Register your unit to update and unlock your maps with Garmin
with the unit off
Plug in your GPS to your computer using the USB connector cable.... your computer will detect new hardware
now go to www.MyGarmin.com and Register your unit get updates for maps and Firmware there,
Garmin will detect your unit and let you download WebUpDater utility to transfer maps
Nov 01, 2010 | GPS
How to install map to garmin nuvi 205w
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Just so you know:
Sorry, no free maps. I know I've tried. You either live with the old map or buy the latest version.
I bought the life time maps updates and I'm glad I did.
I've updated my maps at least 6 times.
New maps are about $70.
Life time maps are about $99 (when I bought mine)
BUT FIRST make SURE you have the latest software in YOUR computer and in YOUR Garmin before you load any maps.
You can get that FREE at Garmin here:
Normal 0 false false false MicrosoftInternetExplorer4 To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 12, 2009 | Garmin Nuvi 660 GPS Receiver
Where can I find free Garmin Nuvi Map Updates?
Sorry, no free maps. I know I've tried. You either live with the old map or but the latest version.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
Oct 17, 2009 | Garmin North America GPS Map Update Maps...
Is there a free update for the garmin nuvi 200?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sorry, no free maps. I know I've tried. You either live with the old map or but the latest version.
Oct 11, 2009 | Garmin nuvi 200W GPS Receiver
I need to update my garmin nuvi
u go to www.mygarmin.com, register the unit and then click updates, I assume you are talking about maps, if so the cost I think for the update is $125.00
I have this same unit, the cost of the new maps is more than I paid for the unit on Ebay.
Sep 18, 2009 | Garmin nuvi 200W GPS Receiver
I'm trying to the free update to my garmin nuvi 310/360'. I've had it a few years and never updated yet. It's not listed in the mandatory software update list. thanks
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Sorry, no free maps. I know I've tried. You either live with the old map or buy the latest version.
Sep 03, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
Going to Mexico and my garmin will not display it.
There are a variety of Garmin® GPS devices that come preloaded with mapping not just for the United States but also for Europe and Mexico. Any nuvi® that has 70 in the model number will have preloaded mapping for North America and Europe.
Example: nuvi 270, nuvi 370, nuvi 670, nuvi 770
Also, some specialty models will have preloaded mapping for North America and Mexico. These units include the nuvi 200 Mexico (p/n 010-00621-2A) and the Nuvi 260W Mexico (p/n 010-00656-37).
To obtain Mexico maps, go to this link:
http://www8.garmin.com/cartography/mapSource/citynavntmexico.jsp#price
Oct 11, 2008 | Garmin GPS
GPS Logo
5,907 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
