Question about SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor
SVA VR 15A flat screen monitor does not complete boot up.
This monitor only works when I boot with another monitor then hook up the flat screen once I am started. When I restart my pc it gets to the windows screen then shuts down to a choice of analog, sleep etc. I have used F8 and have enabled VGA mode but still the same problem.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
It sounds like that monitor has a leakage problem on the ground or shield. This is a common flaw that forces intel motherboards to keep from booting. If you carefully cut the outermost layer of monitor cable away (it looks like a basket weave made of metal threads) that surrounds the other signal cables inside, this problem will go away.
Posted on Nov 24, 2013
4 Suggested Answers
SOURCE: SVA Monitor stuck in Analog Mode or Sleep Mode
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Posted on Mar 13, 2008
Democritus
  • 120 Answers
SOURCE: new flat screen....
With your old monitor connected, set the display to 800x600 or 640x480 (or another low setting) and 60Hz (in advanced settings). Shut down completely. Connect your new monitor, and start up.
After windows boots, set the settings to where you want them. The refresh rate may be the problem here.
Posted on Mar 20, 2009
budmrtn
  • 11361 Answers
SOURCE: SVA VR 15B (Black) 15 in. Flat Panel LCD Monitor: reinstalled windows and sound will not work. i th...
Try www.driverguide.com
Or the manufacturer of the mother board website.
http://s807.photobucket.com/home/budm/allalbums
Posted on May 20, 2010
Conectng securety camera to sva monitors
It depends if the camera has composite video output or is an i.p. camera. Most likely it's composite video output in which case you'll need to purchase a scaler like this one. If the camera is an i.p. camera then you simply use a computer attached to the same router or subnet and open a browser window and navigate to the same i.p. address as the camera, you may need to know password and username to log into stream.
Sep 16, 2012 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SVA 15" FLAT SCREEN MONITOR
maybe you have defective parts in oscillation circuit! in hotside of the power supply! or maybe you have loosed contact at the main board!
Oct 28, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Towers
You could also use better descriptive words and sentences to help me - help you. I have no idea what you're asking. Sorry.
Feb 28, 2012 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Sva monitor model 2400w-bd. have two set up and one keeps going to a black screen after a few min of being on. turn power off and turn back on and screen returns. this is a constant and very annoying...
Your monitor is suffering an overheat condition due to the switcher internally working too hard and overheating, shutting down the switching supply. Replace the electrolytic caps on the board with new low esr ones and you should see this problem go away.
Sep 25, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
I have a flat screen monitor sva but it keeps saying it is out of range
This means your video card is set to a frequency that is too high for the monitor to match. Lower the switching speed via the properties window on the computer. Try 800x600 @ 60hz for starters. You can reboot into safe mode by pressing and holding F8 as you reboot. This will allow you to boot in a low resolution mode which should allow you access to these settings.
Aug 29, 2011 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Can sva monitor be used with emachine
Yes. It would be _stupid_ to design a monitor that was compatible only with _some_ brand-name computers.
Jan 25, 2010 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Sound worked and now it dont
The sound for this monitor is connected with the usb cable that is attached to the monitor cable. Replace the usb cable from the pc to the monitor.
Jul 24, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Sva 15" flat screen monitor
You have a bad power supply capacitor or two. Very common. Not worth fixing, these are free on craigslist *replacement monitors like this
Oct 27, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Blank monitor
Sounds like the LCD mother board is bad. I have the same problem. The board cost $75 at sva-usa.com. I trashed it and bought a use Dell LCD off craigslist for $60.
Nov 05, 2006 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor Logo
134 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
