i have a kitchen aid stand mixer and the head jiggles when it is on and the entire unit "hops" and shakes at high speed. what's going on and how do i fix it?
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers...
(More)
In my area small town in Costa Rica, I am the only one that does maintenance on kitchen aid mixers and there must be around 59 units of different years mostly KSM5 models but others a bit older Heavy Duty and some more. Need maintenance manual for this , how can I obtain same? Parts are available at the capital city Please advise on obtaining thr amnual or manuals.. Speed plates the same for all models?
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to...
(More)
We have Heavy Duty kitchen aid and will not pick up speed. Have changed brushes as they wear out to fast. Rotor on brush end is worn out to a cone shape wear is more in end towards bearing. What do reccomend
