Question about Dell Inspiron 1525 Notebook
Vista boots to blank screen. Mouse pointer moves. Nothing else
Tried safe mode - same problem
Tried safe mode & repairs - same problem
Tried restore
Tried Windows boot disk repair - found nothing wrong
It may be a corupt hibernate file. It did try to hibernate and the power went out. It is a laptop with very little battery life.
  • ottosteve Mar 08, 2009
    possibly vidio drivers. but running dell diagnostics now and video is working. results show no problems
    booted from dell diagonistics disk. also booted from window vista disk and tried its repair function. I have not tried reinstalling vista yet because I dont want to reinstall all the other software.
I can tell you I wrestled with this problem for ages. I had this start at some point without much warning and I thought I was losing my mind. I reinstalled XP, then I installed Vista, then I tried to run all sorts of driver, generic, nVidia, nothing helped. The computer would start, the screen would be grey or show vertical stripes along it. I knew it was not a screen issue because twisting the LCD did not appear to make any changes, I also knew it wasn't the initial wiring because I checked the connection about 50 times along the way.
What I ended up doing is.
1.) I took apart the laptop as per Dell's instructions online, there are several steps, about 20 screws, it's not difficult if you are brave enough to do it. It's very difficult to break anything in a laptop unless you are especially forceful and careful to unscrew everything before prying things open.
2.) I took off the heating core for the Intel Processor and the nVidia chip as well.They are two long copper tubes leading to a very fine heating core which combines beside the fan. The whole thing needed a bit of dusting so I naturally did that.
3.) I carefully cleaned the top of both processors, they have a very smooth surface which is supposed to flawlessly contact a heating distributor and carry the energy out into the fan, there was a grey insulating paste protecting the chips edges but it had gotten between the core and the copper, causing lack of transferrance. Do not leave any oil or residue on the chip unless you want your computer to turn into a bacon pan.
4.) I replaced the heating core and placed a copper coin (penny or whatever) on top of both heating distributors where the chips would be, I put a tiny piece of hockey tape to keep it from wiggling, this is to create more pressure onto the chip as well as a little bit more room for the heat to distribute through the air. It worked perfectly, my chip slowly recovered and I am playing Starcraft 2 on it without a hitch.I'm glad I got through this, it's not the end of the world !
5.) I said a little prayer.
Posted on Jan 08, 2012
    Master:
  • 404 Answers
Graphic card issue. very bad, very expensive to repair most likely a new motherboard.
Posted on Mar 08, 2009
  • lotfi bouakaz
    lotfi bouakaz Mar 08, 2009
    how could you do the dell diagnosis if you're saying you getting blank screen?
  • lotfi bouakaz
    u got no choice, the repair on vista is useless they were obliged to put it to impress their boss but in reality it doesnt do anything
    a clean install will do it.
Samsung DP700A3D blank screen on startup
start the pc in SAFE MODE
1.completely turn off the pc
2. turn it on and as soon as you turn it on click on the F8 keyboard
3. once your doing that another menu should appear
4.click on PREVIOUS SETTINGS THAT WORKED
5.it will load back again if it persists run the steps above again
6. if it doesnt work and continues run the SAFE MODE
7. in safe mode click on start and type System restore and open it
8. select a restore point far away since the incident
9. let it work and restore once finished it will reboot and it should work..
10. if all of this didnt work than you have HARDWARE problems
Jul 26, 2014 | Samsung Computers & Internet
I was updating my avg when my granddaughter touched a button on the computer. She knew she did but does not know which one. Anyhow, the screen went blank. The mouse appears and I can move around but it...
There are a couple ways to fix this , 1. When you turn on the computer as it's booting up start pressing the "F8" button on your keyboard , your pc should load up to a black screen with several options in white text to choose from , try "boot using last known good configuration" , if that is unsuccesfull repeat the previous steps & this time choose "boot safe mode". If you can at least get it to boot into Safe Mode you can undo / repair the changes that occured .
2. If you can't even boot Safe Mode , you can try booting your pc using the operating system installation disc / recovery disc that came with your pc . Once loaded you can select to repair your current installation . Then sit back & wait till it's done , it will reboot & you should be presented with your login screen .
Apr 17, 2011 | Acer Computers & Internet
Vostro 220 with vista boots but screen is black. The mouse moves around but nothing works In safe mode the mouse icon is on the screen but does not move and screen is black. I repair mode it can't fix...
Re install Operating System (Vista)
place the disc Vista DVD in cd/dvd player. Restart your computer and press F12 when you see the Dell logo. pick the option on board cd/dvd player. press enter and start tapping on the space bar to boot to cd. follow the steps in this sites to do a reinstall of Vista.( oh yeah you will lose all your data and files)
http://vistahomepremium.windowsreinstall.com/reinstallvista/index.htm
Feb 22, 2010 | Dell Vostro 220 Desktop Computer
I have windows Vista. I get a black screen when I boot up my computer. The only thing the shows up is the mouse pointer. I tried to recover from last known good configuration. I get the same thing. I tried...
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | ASUS G71G-Q2 Notebook
Blank Screen
HI there.
Try booting into safe mode by pressing F8 while the computer starts up.
If you can get it into safe mode perform a system restore.
If it won't boot into safe mode please post back.
Good luck and thanks for choosing FixYa!!
Jun 02, 2009 | Acer TravelMate 4230 Notebook
Hey i need help quickly on this laptop
Your having data corruption. I think you should consider the REPAIR options or factory restore if it have that cd for the last options.
Just for an input.
Apr 28, 2009 | Medion (40010998)
Vista Home won't boot
NeoSmart Technologies offers a download called Vista Recovery Disk in .iso format. Download and mount the iso with your favorit burning program. Boot to the cd to access the recovery center. Hopefully you'll be able to repair your Windows Vista installation or restore to a known good configuration.
Good Luck
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
Its on but just has a blank screen ??
First see if it will boot in the Safe Mode, pressing F8 when the computer starts up. Choose Safe Mode in the boot option. If it will boot in the safe mode. Restart the computer and press F8 again and select Start in the last known configuration. Hopefully
this will fix the problem. If not and you are running XP Pro, boot in the safe mode and do a restore. you get there by clicking Start, Programs, Accessories, System Tools, System Restore, choose a date that the computer was working and click Restore.
BPCS
Dec 21, 2007 | Acer Aspire 5630 Notebook
Dell Inspiron 1525 Notebook Logo
254 people viewed this question
Alun Cox
