Question about Jenn-Air JJW8230D Electric Double Oven
Jen Air double oven only beeps when you make any selection.
Model JJW9627AAB
Located in my lake house so it is almost never used. Probably has not been used in about 18 months.
The only thing that works is the light for each oven. No clock and when selecting any other functions all you get is a beep.
  • Gordon Warren Mar 08, 2009
    I'll check that next weekend when I get back to the lake house. I know I tried setting Bake, etc but I don't think I left it on long enough to raise the temp.
    Thanks for the suggestion, I'll give it a try.
  • Gordon Warren Dec 20, 2009
    Turned out the clock (display) failed but everything else worked. I replaced the clock and all is good on the lake once again.
    President:
  • Jenn-Air Master
  • 2,651 Answers
Can you look real close at the display, its possibel that the display has "dimmed" and unit is actually working, but just cannot read the display as to what its actually doing, in this case replaccingthe display board will correct your problem
Posted on Mar 08, 2009
Stove causing a very high electric bill
Hello...There are several factors to consider....It's normal for the meter to speed up when you use the oven because the heating elements are high current devices...Several questions come to mind like do you use your over normally on a daily weekly basis??...Do you live in a house or apartment??..What about you heating system..did you use space heaters? or use the over to heat the house? what about Christmas lights and other decorations that use electricity...Were these all current charges?If all this checks out...I suggest you post a complaint or inquiry with your electric company...Let me know the outcome...I hope this was helpful.....PEACE...
Jan 24, 2012 | Stoves Ovens
I tried to fix the wiring in an external light. Did the job, but with bad connections, put in bulb and switched on. Blew fuse and now the switch will not turn off and I am left with a live wire in front of...
Switch contacts fused together
In most external fittings there is a live coming from the switch a neutral going back to the lighting ring main and an earth wire for protection
You are not competant to be rewiring any house wiring , the statement about the earth wire proves that.
No earth is akin to jumping into a lake without a life preserver on
Get an electrician involved before you burn the house down
Dec 31, 2009 | Jenn-Air JJW7530DDS Electric Single Oven
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
New World TGO 70 grill not working because door was closed
THIS IS PROBABLY BEST LEFT TO A QUALIFIED ENGINEER. To reset the grill thermal cut out. This is located under the metal panel at the top of the unit and it is necessary to ether partially or fully remove the whole oven from its housing to get at it. 1. Disconnect electric supply. 2 remove the 2 housing retaining screws. These are located either side of the at the top of the grill cavity. 3.Pull the whole oven /grill unit out and support it underneath to stop it falling forward. 4. Remove metal cover covering top of oven. 5. the safety cut out is a small component that has 2 wires connected to it by spade terminals, in the middle of which is a small red button. push this button gently with the end of a pencil or screwdriver until it clicks. This should now be reset and allow the gas supply to the grill to resume. Finally reassemble making sure that the integrity of the gas and electrical supplies are, in no way compromised and test.
Aug 20, 2009 | Ovens
Electrolux oven eog7330xn stopped working
Hi Chaps,
I have an 18 month old Electrolux Gas oven model No: EOG7330XN which worked for 14 days then died. There was no power displaying and I called Electrolux to service within the warranty period. The engineer removed the front control panel and replaced a fuse inside which brought it back to life.
Am I right this is possible, I have removed the panel but can't see any fuses?
Jul 30, 2009 | Electrolux Ovens
Dimdisplay
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
If you run into trouble drop me an e-mail to dltatsjc@aol.com and I’ll try to help.
Good luck.
Thanks for this site..
May 12, 2009 | Jenn-Air Electric Double Oven
Gaggenau EB 194 Double Oven fuse blowing
from your description, it seems the little fuse is overheating sometimes, a short is a short and an immidiate fuse blower. i would use a higher amperage fuse, 30 amps. any electronic tech can replace this, doesnt have to be your Gaggenau guy, as it seems to me hes made a regular income of this
Apr 17, 2009 | Gaggenau EB294/295 Electric Double Oven
Getting error code F10 on Kenmore model 47889603 wall oven
Leaving the breaker off for the time I was at work (about 9 hours) seems to have cleared the problem. May have just been an abberation and not an actual problem with the appliance. Since the first step with most electronics that develop a fault of some type is to power down for a while then power back up to reset the electronics, I decided to see if that would do it and it did. Thanks for having a site to go to for assistance, though!!!! -Mike-
Dec 19, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
FISHER AND PAYKEL MODEL BICT600E AND SERIAL 87436
Press the two left buttons at the same time and hold them in, then use the + and - buttons on the right to set the required time.
Aug 22, 2008 | Fisher and Paykel AeroTech OS302 Electric...
Jenn-Air JJW8230D Electric Double Oven Logo
159 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
