Home | Coleman | (5040B750) Patio Heater | Charmglow tabletop hea...
Coleman Patio Heater
Problem for Coleman (5040B750) Patio Heater
Charmglow tabletop heater: how do I remove the dome?
By bvogler on Mar 08, 2009
Flame burns yellow constantly. How do I access the air tube at the burner? Does the dome come off?
Solution #1
posted on May 26, 2009
Not Rated)
wineshark
Rank: Apprentice
Rating: 0%, 0 votes
First make sure you have propane. Low propane can cause this too. Presuming its not the easy fix, its probably spiders that have built a web in the venturi (air) tube.
Remove the screws attaching the screen/shield to the body and it can be lifted from the body without taking off the aluminum heat dispersing shield. Next remove the 4 screws holding the burner in place and you should be able to lift out the unit to clean of of the spider webs. High pressure water may or may not work. You may need to use something like a pipe cleaner.
Was this helpful?
Yes
No
Popular Solutions for Coleman Patio Heater
Questions and Unsolved Problems for Coleman Patio Heater
Do you recommend Coleman (5040B750) Patio Heater?
Answer
Answer
What does OH mean on a hot tub control panel
Answer
I have a Charmglow heater, Model HBL-155DLP/M20...both heater lights don't come on...fan works and... (More)
Answer
I have a Coleman Cal Cooperage 107 hot tub. We recently had a power surge. Hot tub turns on but... (More)
Answer
haven't used for a long time Colemann 5040; light works, heater does not / Any suggestions ; valve... (More)
Answer
I have disassembled a large portion of the unit. I can hear the propoane coming out at the top with... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Coleman Patio Heater:
Top Heater Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
