Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Oil light blinking cub cadet model gt 2542 it started blinking the frist time . has oil in the ttractor . tfe tractor has less then 100 hrs 2 yrs old.
  • jamieennis Apr 29, 2009
    I have a cub cadet 2544 with 50 hrs. The oil light blinks all the time and I just changed the oil and filter.
  • Anonymous Mar 17, 2014
    Hi
    I have bike Honda 50cc Cub model 2009 EFI. When I start bike and move to speed 40KM the light in speedometer blinks and after 2-3 minutes bike goes off. When I start after some time it starts and face same problem again.
  • 97 Answers
Screw a test gage in the engine where the electric sending unit is. Check to see what the pressure is cold and after it is warmed up. It may be a bad sender.
Posted on Mar 17, 2009
Cub cadet 1046 kohler courage lawn tractor cranks but does not start
An internal combustion engine needs three (3) things to run..(assuming all internal parts are good)..
1. A properly timed spark
2. Adequate compression >120psi
3. Proper fuel/air ratio
one of these three (or more) is missing...eliminate them one at a time..(this is the way a professional diagnoses a starting issue)
Sep 17, 2017 | Cub Cadet Garden
Cub Cadet 1000 series flashing oil light oil is full?
Hi sounds like oil change indicator this is set for 50 hr intervals there is no reset it will time out after 2 or 3 hrs . Cheers
Nov 01, 2016 | Cub Cadet Garden
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
What type of oil and how much do you use in the Cub Cadet 1440?
It would take 3 and 1/2 pints of Cub Cadet Engine oil (Recommended):
SAE 30 for temps > 40 degrees Fahrenheit
10W30 for temps 0 - 40 degrees Fahrenheit
5W30 for temps
Sep 27, 2010 | Garden
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet oil changing? Every when?
general rule is to change oil every 50 hrs and even more frequently if used in hot / dusty conditions or with heavy loads , check oil before each mow , and clean air filter every 25 hr
change oil filter every 2nd oil change at least
cheers paul
Aug 02, 2010 | Cub Cadet Garden
Cub cadet 1050 changed oil now its wants me to change oil again and it smokes really bad now to much oil or too little
the 1050 holds 57.5 oz slightly less than 2 qts 64 oz. the filler stick is marked. shiould be over the add mark not over the full mark
Jul 18, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My Cub Cadet oil light was on it read 100 hours
Yes, you overfilled it with oil. Drain the oil and fill to the correct level. If you are not sure how much to put in, add small amounts until the dipstick shows a full reading.
Jun 15, 2009 | Garden
Transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Mar 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
664 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
