Question about Homelite ZR10926 16 Chain Saw
Homelite chainsaw will not restart after running
  • Anonymous Mar 17, 2009
    new saw cranks when first used. will not crank after using until cold again.
    Homelite 33 cc chainsaw
  • 211 Answers
SOURCE: homelite runs wide open all the time
hi shoefam
check the cable to the trottle of the carb and the gasket.Disassembly the carb and check it.
savumihai71
Posted on Dec 01, 2008
  • 35 Answers
SOURCE: Chainsaw chain won't move on 16" Homelite bar
Sounds like th clutch brake is engaged. Try Pushing firmly foward on the hand guard in front of the handle. It should click to release the clutch brake.
Let me know if this helps.
Posted on Dec 31, 2008
dontbother10
  • 2220 Answers
SOURCE: chainsaw dont run right
Adjust the "H" needle valve slightly more CCW and try it. This is also often helpful.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
Lou
Posted on Jan 14, 2010
dontbother10
  • 2220 Answers
SOURCE: set carb homelite chainsaw mod ut 10939
No response to CR.
Posted on Mar 13, 2010
  • 4088 Answers
SOURCE: Homelite 10540 chainsaw 35CC chainsaw won't start when hot
Go to: http://www.drystacked com for a 12 page article on Walbro carburetor theory and troubleshooting. Check particularly, the position of the gasket in the lower chamber. Check the spark plug for blue, snappy spark when the engine is hot. If ok, place a small amount of fuel mix in the cylinder and try for start. If it pops several times, look to the fuel system. Check the fuel filter, air filter, and muffler for plugging. Does the primer bulb fill with fuel after several pumps? Check the fuel lines for decay or other damage. When the engine is hot, try not using the choke, but set the fast idle. Hope some of this helps!
Posted on Jul 14, 2010
How do I set idle on my homelite super2 chainsaw
Homelite XL 2 Automatic Chainsaw - YouTube
? 6:12
https://www.youtube.com/watch?v=qk6nk-JQ-zg
Apr 20, 2012 - Uploaded by Alec Ulm's Busted Knuckles
Homelite XL 2 Automatic Chainsaw ... free to shoot me a question or comment and I'll do my best to answer as accurately as I can . ... Homelite SUPER 2 Chainsaw OILER REPAIR & TEST RUN - Duration: ... HOW TO ADJUST A Homelite Carburetor - Duration: 5:01. by smallenginemaster1 177,482 views.
How to Adjust the Carburetor on a Homelite Super VI Chain ...
homeguides.sfgate.com > Construction & Remodeling > Siding
Homelite Super VI chain saws are equipped with a Walbro HDC diaphragm, and ...Adjust the idle mixture screw and idle speed screws clockwise one-quarter turn at a ...Homelite Super 2 Chain Saw Oil Type · How to Replace a Carburetor on a .... MyRidevisit'Cars-My Ride'navigation-www'4 · Sell Your Carvisit'Cars-Sell ...
Need carb settings for Homelite chainsaw - My Tracto
Jan 03, 2016 | Homelite Garden
Homelite Timberman 45 chainsaw runs fine but will not idle. Ideas?
dirty carb specifically in the idle jet turn it in till it bottoms . do not force more then return to the same place it was set if 3/4 turn in turn out 3/4 see if it works better .
Feb 16, 2015 | Homelite Garden
I have a chain saw homelite and the bar leaks oil in my case what do i do
Drain oil back out of tank B 4 you put away , its also a very good idea if you drain and purge gas tank as well , as either of these fluids left in saw will cause u problems if you leave in inside for long periods(< week) when you restart saw
Jun 17, 2014 | Homelite Garden
Homelite xl chainsaw won't start. I took out spark plug, put in some fuel and if fired right up. But won't run.
You need to clean out the carb. possibly replace the Needle Valve and check the Diaphram for stiffness. Also check the fuel line for cracks and rott.
Feb 10, 2013 | Homelite Garden
This homelite chainsaw is bran new
Remove the spark plug and check for blue and snappy spark. If weak or nothing, try another spark plug. If still improper spark, return the machine for replacement under warranty. Make sure you have followed all instructions for re-start. Good luck!
May 24, 2010 | Homelite ZR10926 16 Chain Saw
Homelite xl chainsaw revved up & quit and won't start now
I suspect you have a fuel delivery problem or a dirty carburetor. As a chain saw runs out of fuel they often revv slightly (running lean). HTH
Lou
Oct 06, 2009 | Garden
Saw will not stay running
It sounds like it is not getting enough fuel to keep it running. There may be a clogged screen in the carb or dirt somewhere in the carb. Another thing you can check is the adjustment on the carb.
Jun 19, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite chain saw difficult to restart after refueling.
Are you pumping the primer till it's full first?
Mar 09, 2009 | Homelite Garden
Dec 29, 2008 | Homelite Consumer Products 9.0 Amp, 14 In....
Homelite ZR10926 16 Chain Saw Logo
367 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
