Question about Logitech G15
Logitech G15 spacebar
Basically i took the keys out of my Logitech G15 to clean the underneath.
i didnt realise how fragile the plastics under the spacebar was and one of the top parts of the little holders for the metal support bar snaped, now my spacebar dips (and consequently wont work when i press 1 side of the spacebar.
Anyone know of a repair kit or how have people overcome this problem before.... seems wastefull to buy a new one just because of this but at the same time it will get so annoying
  • wallofchaos Apr 13, 2009
     I am on my 3rd keyboard now. the very 1st day i get it the damn thing breaks. I am getting so flustrated with this. How can such a nice expensive keyboard be such a piece of ****?
down_grunger
  • 47 Answers
SOURCE: logitech cordless keyboard erratic after cleaning keys
seems to be that you may have accidentally swept some dirt underneath the keys.
try pressing each key individually in word and narrow down the affected key or keys, then remove the affected keys (using a keyboard key removal tool, or very carefully by hand) and clean underneath the key with a small dry clean brush both under the key and the board section it lay in, then replace the key and type the key again, if that has no luck then try the process again.
hope this helps
kev
Posted on Dec 01, 2008
  • 34 Answers
SOURCE: spacebar-quit-working-after-cleaning-the-gunk-unde...
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Posted on Feb 19, 2009
SOURCE: Logitech wireless keyboard not working
After changing the batteries and cleaning the corrosion out of the battery case, I pressed the connect button on the Logitech receiver, then the red restart button on the underside of the keyboard and it was fixed!
Posted on Mar 26, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Dead Micro-switch
Unless the mouse uses a real oddball microswitch, it would be fairly simple to unsolder the bad switch and replace it with a new one. I have done this on many mice. You can check with computer shops in your area and see if any of them might try the repair. (A TV shop could also do it, but they're not likely to have a few old mice lying around to take a replacement switch from, while a computer shop probably would.) I have no idea what labor rate the shop would charge, but it would certainly exceed the cost of a new mouse. (The shop I formerly worked at would have charged $20, but this was 5 years ago.) However, it might be worth the cost if what you have can't be replaced with something comparable.
Posted on May 12, 2009
plettdoctor
  • 121 Answers
SOURCE: spacebar,wont,work,after,spillin small,amount,o...
The sugar goes into the contacts and permanently deamages the keyboard. NOT REPAIRABLE. The laptop keyboards are not very expensive. You will only get that problem solved by replacing the keyboard.
Posted on Jul 20, 2009
Spacebar problems
You need to reattach the rubber nipple facing up. It's the part that makes contact with the board to signal to the computer the spacebar has been pressed. Most of them are free floating under the key or even gluing it on would be fine. The keys can be a bit tricky to pop off. Use a plastic pry bar, you an find these online for a couple dollars.
Jun 21, 2013 | HEWLETT-PACKARD Hewlett Packard HP Mini...
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Logitech G15 Keyboard not detecting WoW or other games
The follwoing threads talks about your problem, with solutions posted:
http://forums.logitech.com/logitech/board/message?board.id=hardware&thread.id=71
Basically,
  1. You need the latest WOW patch to get G15 LCD support.
  2. The applet for WOW launches at the Login screen for WOW. Until then it will not show up at all in the LCD control panel for the G15
  3. The search you did for WOW is only for the profile which does not do anything with the LCD. It only handles programming the G-Keys. When the applet launches it should display "World of Warcraft" in the LCD. Nothing about the profile launching. That's a different thing.
  4. Even though the applet for WOW is running, it may be disabled in the G15 software. To check this launch WOW and go to the login screen. Then go to the G15 LCD Control panel and make sure the box next to the WOW applet is checked.
Basically, for other software/games which don't have built-in support for the G-15, you'll need to download a custom LCD applet in order to display specific software/game info on your LCD when you launch that software/game. You can find good applet at g15forums.com.
Hope this helps
Jun 16, 2009 | Logitech G15 Gaming Keyboard
Took spacebar off to clean up a pop spill...metal bar NOT attatch
There might be a metal wire if it is missing, which snaps to the keyboard, you may need a new keyboard.
If you are unsure, you should probably thake it to your local computer repair shop.
Good Luck.
Mar 15, 2009 | IBM ThinkPad T42 Notebook
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
Feb 18, 2009 | Logitech 967437-0403 Keyboard
Keyboard spacebar sticking
Just solved it, after a bit of tinkering...
the prongs of the floating plastic frame need to sit inside the clips of the spacebar key, you can't just clip it back on with the prongs either up or down. It's fiddly, you need a paperclip or thin screwdriver to do it, but it's stopped the sticking problem.
Oct 25, 2008 | Dell OW7658 (J4624SK8115RT7D50) Keyboard
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Broken Key
You could look for a key that would physically fit from another keyboard that you'd "slaughter" for that part. The dimensions must fit, and the fastening method. Here's what you'd do to remove the key, and this would also give you some info on the fastening method: http://theonegreatx.com/2006/12/08/how-to-clean-your-logitech-g15/
Apr 22, 2008 | Logitech G15 Keyboard
Logitech G15 Logo
1,196 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
