Question about Sony VAIO VGN-NR120E/S Notebook
My daughter got a new hard drive for her Sony Vaio laptop... it connected fine to the internet at her friend's house (the guy who fixed it), but when we get it home, although it shows that it is currently connected to our network, she cannot access the internet. HELP!!!
  • paulamay11 Mar 08, 2009
    I understand that... but what could prevent internet access when the computer says it is currently connected to our network (and my HP laptop is just fine)?
    Master:
  • 404 Answers
Hard drives dont bring internet? unless i am missing something here. hard drives are to save data into.
Posted on Mar 08, 2009
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
I pruchased a Sony VAIO VGN-TXN15 Notebook from a guy on ebay who said the notebook worked well. Unfortionatly It does not connect to the internet wireless or with the eithernet cord. I took it for a...
Did you tried cable connection to your router to see if this works?
which windows its runing on?
If wireless connection drops its not all the time your laptop issue... its router transmitted channel conflict with laptop wireless card channel....
You might fix this by changing the router wireless setting by changing the transmission channel on it.and then re connect the laptop or it may auto reconnect with it and hopefully signal will not drop.
one is network card for cable connection to internet
one is wireless card for wireless connection to your router(with internet connection)
I will write more after I get your reply. As I am in the middle of my own issue now... ;)
May 08, 2011 | Sony VAIO VGN-TXN15P/B Notebook
Sony Vaio PCG-9H4L cannot find hard drive
you can try to go to bios pae and check if the system can detect the hard drive.If not you might need to call call Sony to check if the system is still on warranty so that they can replace the hard drive free of cost if not you might need to replace it with a new one
Jul 30, 2010 | Sony Computers & Internet
Sony vaio laptop unable to detect new hard disk
Try connecting the drive to another pc with a usb adapter, create a partition and format it. Then put the drive back in the vaio and reinstall windows. This should fix the problem.
Aug 09, 2009 | Sony VAIO TR1MP Notebook
Sony Vaio desktop will not load windows
what your describing is a hard disk failure the computer cant or wont read the hard disk to boot the machine, so it shuts down. Sounds like the hard disk died from a bad virus. and the computer wont run. Best I can do for you is either format the Hard disk and reinstall the operating system or buy a new hard disk. Cheers
Apr 01, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
Wireless Connection Difficulties
sounds like your wireless card in your laptop needs either a replacement, or new drivers.
www.sony.com
May 23, 2008 | Sony VAIO VGN-FJ290P1 Notebook
CMOS Battery
you want to be looking for the rtc(real time clock) which is a little unit not much bigger than ur thumb nail.next to it youll find the battery(sometimes heat sealed with plastic.)if you remove this battery for about 5 mins then replace it or in ur case maybe renew it this will reset bios to factory(also method for bypass passwords as every thing is reset)
you might also wanna check ur video card.(connections and dust)
Mar 04, 2008 | Sony VAIO VGN-FS640W Notebook
Page cannot be displayed
make sure that the password is exactly like it should be.
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Sony VAIO VGN-NR120E/S Notebook Logo
155 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
