Question about Maytag Atlantis MDE6400AY Electric Dryer
The dryer won't turn on. The timer is ticking though
I never had any sign of problems and the dryer just stopped.  The timer still ticks and the vents are clean. It won't do anything, we've checked the circuit breaker
    Problem Solver:
  • 16 Answers
Check the door switch with a multimeter or be carefull and pull or cut the wires on the switch then splice them together tape the splice and start the machine or remove the switch and get a replacement from an appliaince parts place or radio shack.
Posted on Apr 11, 2009
Dryer doesn't start
Actually, it's probably the switch under the button meeting its demise.
Jan 14, 2018 | Whirlpool Dryers
Haier dryer ticking noises
ticking you hear is the timer motor,drive motor is most likley geeting too hot.check vent ,dryer pushed back too far?hose kinked ?stopped up?too long?vent should be short,straight and of hard pipe.clean vent twice a year,heating element will love will not love to replace it.
Mar 15, 2014 | Haier HLP140E Electric Portable Dryer
Whirlpool dryer shuts off at the end of cycle, but timer continues to tick. It ticks through the next cycle and stops ticking at that cycles off?
follow this steps and fix it. God bless you
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is faulty replace it If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. Replace it.
Oct 01, 2013 | Whirlpool Dryers
My Kenmore dryer ticks constantly (runs fine)
sounds like the timer running,put your ear to the timer dial to see
Jan 14, 2013 | Kenmore Dryers
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
Whirlpool Ultimate Care II gas dryer won't turn off.
Dryer Won't Stop Running
  • Ultimate Car II Dryers are fitted with a mechanical timer that sends an impulse to the control circuit board to stop running once the set amount of drying time has elapsed. This is because, should an electronic timer fail, this would necessitate the replacement of the entire circuit board. Confirm that the mechanical timer is indeed broken by opening the dryer's door. If the dryer stops, the circuit board is working fine and is not the problem. Simply slide off the protective faceplate of the dryer, unscrew the control board beneath, and flip it over. Connected to the back of the timer's knob should be a small round device with two wires running to the circuit board within the body of the dryer. Unscrew this device from the back of the knob and disconnect the wires. A replacement timer costs a few dollars and should screw into place without trouble. Reconnect the wires and put the dryer back together. It should work fine now.
  • If you need a new timer the best place ti get it is from Rough River Appliance Repair
  • Phone number is (270) 230-1818 his name is Charlie and he is the best!
Nov 16, 2011 | Dryers
Nob for setting time keeps ticking after dryer has stopped cycle
the timer dial you set is at fault. A replacement will be needed soon for it will just quit some day soon
Jun 30, 2010 | Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Maytag Atlantis MDE6400AY Electric Dryer Logo
212 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
