Question about Protron PD-007 DVD Player
1998 Older TV, Dish Network and DVD Player I can't set up
My TV doesn't have the RCA cable plug ins in the back. How can I set up my DVD player with this older TV while on Dish network?
Try getting an rf modulator, they are about 20 bucks at walmart, i had to do that for my dad, his tv had the hookups but it still wouldn't work. try that you might be able to hook up the dvd, tv, and dish network plugs all in one.
Posted on Mar 08, 2009
How to hook up an old RCA 14 inch tv to DVD
Easy. All you have to do is to make sure that the DVD player is old the older types that have RCA connectors at the back of the DVD. Latest DVD may have RCA connections but I am not sure if it can send digital signal directly to the analog TV. Try this and see what happens. if your TV is old and does not have Component Video (Red/Green/Blue) RCA sockets (input) but has standard Pal/NTSC sockets (Yellow/Red/Black) hook up the yellow, red and black plugs into a DVD (out) RCA sockets of same colour, then hook up the other end of the cable in the (in) RCA sockets at the rear of the TV.
If it works, then all is well. If it doesn't work, then you have to hook up the cable from the DVD to the (input) RCA sockets of a Set Top Box, so that the Set Top Box will convert the signals for the analog TV. Just pay attention to the inputs and outputs at the rear of them.
On your DVD - plug the RCA cable to the (OUTPUT) RCA sockets. On the Set Top Box - plug the connectors in the (IN) RCA sockets and then use another cable connected to the OUT RCA's of the Set Top Box, then connect the other connectors to the (IN) of the TV RCA sockets. Hopefully you get the picture on what I mean.
Sep 01, 2014 | Televison & Video
RCA DRC247N DVD Player No Audio
The separate DVD player has three output cables: video (yellow), right audio (red) and left audio (white?). These connect to the corresponding inputs on the TV. If your cable box also has three similar output cables, you probably do not have a second set of inputs on the TV so what to do? You can purchase three Y adapters that combine two female RCA connectors into one RCA plug and plug everything into your one set of connectors on the TV. However, if your cable box output connects directly to the TV antenna input, the solution is simpler. Post a comment if this approach is not going to work
Oct 13, 2012 | RCA DRC247N DVD Player
I'm trying to hook up my dvd player to my tv and dish network system. I had disconnected it a couple of months ago before having some renovations done in my house, and I can't get it back to how...
If you have HD TV it is best to hook up the DVD player separately.
The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input".
Next take another cable and connect it from the DVD player output to the TV. Make sure your TV set is tuned to the correct channel and input and you're all set. If you need further assistance please reply here and I will see to it this gets resolved.
Daniel Busa
DISH Network
Customer Service
May 22, 2011 | Emerson EWD2204 DVD Player/VCR
I want to burn a dvd from what I have recorded in my dish network. How do I set up the player so I can watch the tv through it?
Next take another cable and connect it from the DVD player output to the TV. You may need to cycle or change your input by pressing the input or source button on your TV, in order to get a picture.
Daniel Busa
DISH Network
Customer Service
Mar 26, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have dish network and would like to know the proper way to install this unit.
If you have HD TV it is best to hook up the DVD player separately. The easiest way to connect this is to find the cable going from the receiver to the TV and disconnect it from the TV. Connect this cable to the back of the DVD player where it says "in" or "input". Next take another cable and connect it from the DVD player output to the TV.
Daniel Busa
DISH Network Customer Service
Feb 01, 2011 | Durabrand DVD-1002 DVD Player
How do u hook up the dvd player and dish network to your tv
The easiest way to connect your DVD player with your TV, is to find the cable going from the receiver to the TV and disconnect it from the TV.
Next take another cable and connect it from the DVD player output to the TV. Once you've done this make sure your TV set is tuned to the proper input or source. Your DVD's should play when the receiver is off, however, you'll probably need your DVD player on to get the DISH signal.
Daniel Busa
Dec 10, 2010 | Sanyo DWM400 DVD Player
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
Connecting protron dvd to dish TV
I hope you have at least 2 sets of RCA jacks for (1) the Dish receiver and (2) the DVD player. Run 2 sets of R/W/Y cables to the TV. Done. Or use S-video for a better picture instead of yellow.
If you only have one composite input on TV (possible) then either buy a 2-way or more switch for the composite signal (R=right sound W=left Y=composite or S-video instead of composite) or you can instead pass the signal through the DVD recorder on the RCAs but the DVD will be on whenever anything is on. I assume you do not have a Dish 111 with only RF output but the same could be done for just the wimpy RF, just different switch. So there will be 3 RCA cables from Dish to a recorder and 3 then to the TV. Since you do not have a recorder, then go back to the switch or find another TV input.
Ten years, hum, you may not have had composite/S-video inputs and would have to use RF only--you did not say what TV was.
-Ken
Jul 19, 2009 | Protron PD-800 DVD Player
Connecting DVD to cable only TV and Modulator box and Dish Networ
Without knowing the actual ports on each of these devices, all I can suggest is that have you tried connecting your DVD to the Dish box (thru VCR scart connection at the back of the Dish box) and then the Dish box into your modulator (and then modulator into your tv.
I have a similar system set up but we have a Sky Digital box here, no idea if its the same as a Dish box but im assuming so.
Jan 01, 2009 | GPX D1816 DVD Player
No audio
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Jan 05, 2008 | RCA RC5510P DVD Player
Protron PD-007 DVD Player Logo
136 people viewed this question
Top Protron Televison & Video Experts
Dave Naylor
Dave Naylor
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
