Question about Texas Instruments TI-84 Plus Calculator
Arcsine doesn't work?
Whenever I use the sin-1 button, the ERR:DOMAIN thing comes up. Is there a way to fix it?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Arcsine is only defined for arguments in the range [-1...+1]. If you supply an argument outside that range, you will get a domain error.
Posted on Feb 19, 2010
Err domain
You tried to use an argument to a function that was not in the function's domain. For example, the arcsine function takes an argument from negative one to positive one. Trying to take the arcsine of 2 will generate a domain error.
If you need further assistance, please specify the exact function and argument that is generating this error.
Oct 15, 2013 | Texas Instruments TI-83 Plus Calculator
How do you input arcsin
Press 2nd then SIN then input the arcsine.
Jun 22, 2013 | Texas Instruments TI 30XIIS Scientific...
When i try to do a inverse function e.g sin^-1 90 i keep getting error 2 can anyone help me
It seems that you are trying to calculate the inverse sine (arcsine) of 90. However the domain of definition of the arcsine function is the closed interval [-1, 1]. Any value outside of this interval will result in an error.
Apr 20, 2013 | Office Equipment & Supplies
I put in the arcsin (sin^-1)(128) and it gave me domain error. How would i re-write this expression to get the answer i need?
The arcsine function only takes arguments in the range of negative one to positive one. 128 is not in the domain of the arcsine function.
Could you post the problem you're trying to calculate?
Feb 16, 2011 | Texas Instruments TI-83 Plus Calculator
Ive been doing inverse sine, inverse cosine, and inverse tangent problems for a few hours now but all of a sudden when i put in this one problem it gives me: ERR:DOMAIN. im not sure what is wrong... I've...
Since you are familiar with sines, cosines, you know that their ranges (interval of values) varies from -1 to 1. The inverse functions of sine and cosine tkae their values in that very domain, [-1,1].
However you fed the arc sine function (sin^-1) a vlaue of (25/20.48) and that value is obviously larger outside the [-1,1] domain, hence the DOMAIN error message.
No such domain limitations exist for arc tangent (tan^-1) because the range of the tangent function spans the open interval ]negative infinity to positive infinity[.
Nov 02, 2010 | Texas Instruments TI-84 Plus Silver...
I get err:domain on my TI-84 plus when i do Sin -1 (60) why?
While the domain of the sine function is the whole of the real line, it range spans the interval [-1,1]. In other words the sine of an arbitrary angle is imperatively somewhere in the closed interval [-1,1].
So when you want to find the arc sine corresponding to a given value of a sine function, you cannot give as argument to the arc sine [sin^-1] a value that lies outside the interval [-1,1].
For your case, the argument is 60 and it is outside the permitted domain [-1,1]. That is why the calculator protests by signaling a domain error.
Oct 28, 2010 | Texas Instruments TI-84 Plus Calculator
How do you use the sin-1
You would press on the SIN key, "sin(" should come on the display, then enter the value, for example 3.5 or -1 so that the display shows
sin(3,5) or sin(-1) for example.
remember to close the sin with the ) on the end.
sin(-1) = -0.841470985
Feb 16, 2010 | Texas Instruments TI-30XA Calculator
I keep getting ERR:DOMAIN when ever i do the inverse sin
inverse sine (sin^-1) gives you the angle when the opposite side length and the hypotenuse, in relation to that angle, are given. therefore, if you want to do sin^-1(x), 0<x<1 for all real triangles ex. sin^-1(1/2) would equal 30. if you get a decimal, then go to [Mode] and select degrees instead of radians to get angle measures instead of radians... :)
Apr 23, 2009 | Texas Instruments TI-83 Plus Calculator
Can't take inverse of sin
The inverse sine is only defined for values in the range [-1..+1]. Arguments outside this range will produce domain errors.
Apr 14, 2009 | Texas Instruments TI-83 Plus Calculator
"Err: Domain"
I think you may find arcsin(x) is equivalent in older nomenclature to sin^-1 (x)...ie use the "2nd" and the SIN key instead of typing arcsin.
eg. arcsin(0.5) is 30 degrees is the same as sin^-1(0.5)
The ^-1 does not mean reciprocal, but "the angle whose sin is." Here the minus one indicates a kind of inverse operation. The word arcsin indicates that same inverse.
Mar 23, 2009 | Texas Instruments TI-89 Calculator
Texas Instruments TI-84 Plus Calculator Logo
1,097 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
