Question about Garmin StreetPilot C330 GPS Receiver
Low Battery after using it
Will not charge in my car? bought new cigerette lighter device, Did not fix the problem, I can charge it on the computer.
  • sondrassheph Mar 09, 2009
    But it is going on 2 years old. So there would be no warranty???
I had the same exact problem about three years ago when mine was new. I sent it back to Garmin and it took some convincing on my part to get them to replace the mount and cable for the car. The first time I sent it back they only wanted the unit back, not the mount. Same problem when i tried the replacement unit. I called service again and told them that I was sure it was in the cable from the cig. lighter socket and that I was going to send the whole system back. They said ok and when I received it back from Garmin the second time I had anew mount and it has been fine since. By woodtick
Posted on Mar 09, 2009
Low battery
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Jul 18, 2014 | Garmin NUVI40LM 4.3" GPS US Mapping Text...
Cigerette lighter adaptor for my 2010 camry dont work
do not change the batery. If the car still runs fine the problem is a blown fuse. Find the fuse panel, On the back side of the fuse panel cover is the fuse location chart. Look for the cig lighter fuse it is probably 20 amp
Sep 18, 2012 | Toyota Camry Cars & Trucks
My bracket for my suction mount broke so I cant use a cigerette lighter charger is there another way to charge my GPS
If you were using a standard Nuvi 3xx cradle, pull the charger cord from the back of the cradle and plug it into the side of the Nuvi, into the mini-USB port. You can charge it that way.
- Jim
SHARCNET-USA
Oct 24, 2010 | Garmin Nuvi 350 Car GPS Receiver
Got a Marlboro Power Pak at a yard sale. He said it was never used but it did not come with an AC power cord to charge it. I plugged in what came with it to my cigerette lighter and it did not charge. Does...
Charging via your cigarete lighter would be VERY SLOW, especially if the device has sat aaround and discharged.
If it has a place to plug in AC, often one can find cords at thrift stores that will fit the connector.
Some of these used wall transformer units supplying 13 or 14 volts to charge.
The battery may be so far down it may damage the charger.
Apr 27, 2010 | Electrical Supplies
Honda goldwing 1100 1981 i bought an air pump pluged into the cigerette lighter and blew a fuse i hope everything else works but the radio and the cigerette lighter can you help?
A better answer than 'just replace the fuse', is to install a new lighter socket near the battery with a new fuse holder and a heavy enough fuse and wiring to sustain the current draw of the air pump. Connect the wiring (with fuse) directly to the battery connections. Hope this helps.
Oct 19, 2009 | 1981 Honda GL 1100 Innerstate Gold Wing
Cigerette lighter has no power 2001 pruis, fuse looks okay..
try sticking in a new fuse. just to be sure. and have u tried more than one device in the car cig lighter? if not, try something else to verify it doesnt work
Jul 09, 2009 | 2001 Toyota Prius
Cigarette lighter wont work no more on my 2001 aurora
1st check all fuses. 2nd why do you need to charge all the time? If your battery keeps going low and you have to charge it all the time , perhaps you need a new battery. If the charger has to give the battery a large charge then it may have caused the fuse to fail on that circut. . Is this device for a cell phone? If it is then you probably blew a fuse. Let me know if you are charging the car battery or charging a cell phone battery.
May 09, 2009 | 2001 Oldsmobile Aurora
Charging the battery in Nuvi 760
1) Check the cigarette lighter is working by plugging in the lighter unit and see if it gets hot. If it doesn't then it is possible the fuse has blown.
2) You can plug the unit into a PC using the USB cable and if there is a fault you will get a message on the screen about 'USB over-current' but it shouldn't damage the computer.
If it runs/charges using the PC and (1) is OK then you may have a problem with the cigarette lighter - cradle cable or a problem with the cradle itself.
HTH
Peter
Jan 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
102 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
