Question about KitchenAid Refrigerators
Power and no lites in refrig/freezer; beeping
Have a KitchenAid built-in refrigerator. Needed to replace light bulb and now the power is on but the electronics at top showing temperatures will not display and I keep hearing a beeping. anyone have a clue?
    President:
  • KitchenAid Master
  • 2,651 Answers
Depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Posted on Mar 08, 2009
Side by Side Kitchen Aid refrigerator. Top to 40W bulbs burnt out at the same time but the bottom veggie light still works. Switch at top right side of fridge toggles the bottom light but the top lights still don't work with new bulbs??
Posted on Feb 24, 2013
How do I change the freezer lite bulb?
A bulb is a bulb is a bulb. Unscrew and replace.
It might be behind some cover - if so remove the cover and unscrew and replace and put the cover back on..
Sep 04, 2015 | Maytag Refrigerators
How to replace kitchenaid superba light bulb
The light bulb on the water/ice dispenser on our Kitchenaid Superba side by side refrig needs replacement. Easy! Right?
However it is screwed in so tightly and the location is behind the panel is so small, it it very difficult to get a grip on it to unscrew it!
We,ve tried rubber gloves, WD-40 and an Exacto knife(w/ fuse turned off!) and still cannot get this very annoying light bulb out!!
Does anyone have any ideas or can we remove panel it hides behind to get to it!!!???
Thanks for any info on this should be simple issue!!
Susan M
Jan 15, 2012 | KitchenAid Superba Architect KSCS25INSS...
Every 15 seconds the refrigerator beeps and i noticed the refrig light was out. I replaced the bulb which is now working but it still beeps every 15 seconds. tThe temperature in both the frig and freezer...
I don't know if you have an ice maker but when my ice dispenser is full my fridge beeps because the ice can no longer go into the tray because it is full so I have to empty the tray. and the beep stops it also beeps when the water filter needs changing. I hope this helps
Feb 23, 2011 | Refrigerators
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Freezer is on but cold air not going into refrigerator
the damper door is not opening up to let cold air from freezer into refrige compartment,it may have frozen shut from moisture or the cold control isnt powering it,defrost it if ice covered,then adjust cold control and see if it opens and closes,otherwise check the control and power to the control
Jan 17, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
My Call Service light is on and the refrig. keeps beeping
unplug unit overnight and let defrost, return air ducts are iced up
Oct 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid top shelf warm
  1. check gasket
  2. check the light switch on top of the refrig. section. If then pushed the switch turns the light off, but the light is still on with the fridge door closed - door needs adjustment.
Oct 13, 2009 | KitchenAid KSS48QM 48" Built-In...
Freezer & refrig not cold
change the filter. to do this recover the freon(gas), remove the filter , replace it by new one; do the vacuum and then charge again. Work must be done by a certified technician. do that at your own risk
Aug 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Leveling Kitchenaid Side-by-Side Refrigerator
refrig. not cooling, thinking we had a power surge and now the freezer is not freezing and the refrig. side is not cooling. It makes a sound like it may try to engage, but to no avail.
Apr 13, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
568 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
