Question about Briggs & Stratton Garden
Replacing engine. Briggs 26hp on GT5000 garden tractor
Replacing engine. Briggs 26hp on Craftsman GT5000 garden tractor and would like manual for removing and replacing .
  • 13 Answers
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
My 26hp kohler is not pumping fuel from the tank to the carb. and it has a new filter and pump.
if it has a fuel pump , overhaul the pump or replace it
otherwise replace the fuel hose to the carby/filter
Mar 31, 2016 | Craftsman Garden
What is the gap gauge for craftsman pyt 9000 lawn tractor 26hp
If you are talking about the spark plug, I would need the model number of the engine.
Jun 15, 2014 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a craftsman gt5000 garden tractor 24hp els motor that threw a rod, the end cap broke loose.will the briggs and statton 27hp model 44Q777-3136-g5 work as new motor,the cranksaft dia. and length are...
There should be no reason why not, Just keep in mind of the bolt pattern and measurements as well as you may have to make a few altercations for cables but if shafts match you should be good to go! I hope this helps.
Sep 25, 2013 | Craftsman 24 Hp 48" Deck Yard Tractor
How do I wire a 18hp Briggs & Stratton engine to a craftsman GT5000 lawn mower
I dont have all your anwers. In my experience, Kohler frequently has wires to start, run and stop the engine. They also frequently have a low oil and/or high heat control (engine shut down). Also expect a wire from the charging system. On your tractor, you probably have similar plus 'operator presence' wires. These wires require to you to be sitting in the seat for the machine to operate - a seat switch for example. On my tractor, I can depress the 'brake' (which isnt exactly a brake in fact) and the engine will run when I dismount. However, if the mower is engaged, no matter what, if I get off the tractor, the engine shuts down.
You will have to determine what every wire is for and connect it properly. You may lose some engine 'functionality' or tractor safety features. It is never easy to put a Ford starter on a Chevy. Good luck with your project.
Thanks for your interest in
Dec 02, 2012 | Garden
I have a craftsman gt5000 26hp 54" deck. I removed the cutting deck cleaned and replaced blades then when i put it all together the belt wont fit. Theres a belt tensioner rod that i disengaged but...
Belts do not change length. You are doing something wrong with the routing. Maybe the tensioner goes on the other side of the belt or the belt should be routed around the other side of both the tensioner & idler.
Jul 06, 2011 | Craftsman GT 5000 26 HP54" Garden Tractor...
Craftsman 26HP Lawn Tractor Parking Brake
There is not an adjustment on the parking brake. The problem you are having may be caused by the drive belt stretching.
Jul 06, 2017 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
One cylinder won't fire
You need to check spark plug wire to that cylinder I have had the same problem where a mouse ate insulation off wire ,Your engine has a coil with two wires one runs each cylinder I have had them go bad where only one fired you would need a new coil .
May 07, 2009 | Craftsman 24 Hp 48" Deck Yard Tractor
Garden Logo
415 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
