Question about Roper REX4634KQ Electric Dryer
Dryer won't start
I have a roper electric dryer and it won't start. I read a bunch of posts on here about the problem and ahve cleaned the vent and changed the thermal fuse and it still won't start. I know electricity is getting to the dryer because when I set the time I get that "ticking" noise, but when I press the start button nothing happens. what's my next move?
    Problem Solver:
  • 15 Answers
Posted on Apr 07, 2009
I have a electric roper dryer. Will not turn on. Worked fine this morning. Changed loads now won't turn on at all
Remove the back dust cover and check the blower fuse. (skinny white one screw 2 wires) If it is open remove and clean the filter housing, Clean the vent. My home video shows all the components and how to check.
Jun 28, 2013 | Dryers
Load takes more than one cycle to dry. cleaned vent.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
May 10, 2010 | Roper REX4634KQ Electric Dryer
Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Jul 27, 2009 | Roper REX4634KQ Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Roper dryer will not start it is electric
The thermal fuse is probably open again, This condition is caused by restricted air flow out the vent system. Replace thermal fuse again and clean the vent hose and vent hood outside
Jan 05, 2009 | Roper REX4634KQ Electric Dryer
Clothes not drying
clean vents, including exhaust vent
Dec 16, 2008 | Roper Dryers
I ahve a Roper dryer that won't start. It started acting up a few
HI thanks for the question Thts a sure sign of a bad motor, stopping In the middle of a cycle. and then starting again, and now no start replace the motor
Nov 24, 2008 | Roper REX3614KW Electric Dryer
Not drying
I know you cleaned the lint vent but your vent hose is clogged or damaged and there is no air exchange thru the dryer Air can only hold 100% humidity. You could dry your clothes for 10 hours but the air in the dryer is saturated with water and can not hold anymore so your clothes wont dry. Check behind your dryer and Ill bet the vent line is damaged. The problem is the air is not getting out of the dryer. Check the flapper at the end of the vent line. With the dryer running go to the end of the vent hose and there will be no air coming thru.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Roper dryer
if you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place then can pull complete housing out back
May 18, 2008 | Roper REX4634KQ Electric Dryer
Roper Gas Dryer
hi first thing to do is clean all the venting and try again. thanks the appliance doc
Apr 19, 2008 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
247 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
