Question about SonicWALL Pro 5060F Firewall
SonicWall 5060 will not reset to factory default
I am trying to reset my SonicWall 5060 to factory default, i have tried the reset/power option, however, the test light just blinks red.
  • Anonymous Mar 20, 2014
    default settings
    Problem Solver:
  • 8 Answers
there is notch on sonicwall to reset it.
Posted on Mar 18, 2009
I am forget the my sonicwall administrator password. how to login
Hello and Welcome to FixYa!
You can't login, all you can do is to reset the SonicWall. There is a small pinhole on the front panel, hold it for some time... that will boot it in a safe mode to reset it.
I hope you have a clear picture now.
Concerned, Nooh.
Jun 10, 2011 | SonicWALL Pro 2040 Firewall
I am a admin at a new company and they do not know nor can they find the Admin login and password. Is there a way to hack in to the SonicWALL PRO 230 Firewall unit?
Deafault user: admin
password: password
default ip: 192.168.168.168
if in case you cannot get in, you need to reset the device to its factory default.
thanks
eric
Oct 29, 2010 | SonicWALL PRO 230 Firewall
I forget my sonicwall admin password how will reset this password
If the SonicWALL's admin password is lost, there is no backdoor or other mechanism to bypass the administrator login. Please note that prefs files do not contain the admin name and password. So if you reset the firmware and import a current prefs file, you can gain access using the default login credentials ('admin' & 'password'). Without a current prefs file, you must reset the firmware and configure from scratch.
For models running SonicOS (Enhanced or Standard), you can reboot to factory defaults. This resets all settings including the admin name, password and LAN IP address. Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login.
For models running Firmware 6.X, you must reset the firmware (wipe and upload using the reset procedure). Import the current prefs file. The configuration is restored and use the defaults 'admin' and 'password' to login. The 'Reset to Factory Defaults' button does not reset the admin name, password or LAN IP address for these models
Feb 03, 2010 | SonicWALL PRO 1260 SonicOS Enhanced...
Can not connect to sonicwall tz190
hi
In factory default,DHCP is enabled just connect any pc and see whether you are getting any ip.
Regards,
Mani.S
Feb 25, 2009 | SonicWALL TotalSecure 3G (TZ190)...
Unit will not resolve DNS
Ditch the Barracuda and use the SonicWall Content Filtering option, it's cheaper anyhow.
Barring that, reset it to default, and make sure that it is using the SonicWall as its gateway, along with the proper DNS settings. Also, check for a firmware upgrade on the unit. I've run into a few Barracudas that have nothign in the knowledge base but a firmware upgrade fixes them.
Sep 16, 2008 | Barracuda Networks Barracuda Web Filter...
Cannot connect to SonicWall VPN
My guess is that dhcp is using the same private network scheme. Try changing your home network scheme to something different than your office.
For example:
Office = 192.168.1.x
home = 192.168.2.x
Aug 26, 2008 | Westell Wirespeed VersaLink...
Sonicwall 330 pro
If it has a reset button, you'd want to try holding it down until you see the lights flash to let you know the reset completed. It should be fine after that, unless the power surge toasted it for good.
Dec 10, 2007 | SonicWALL PRO 300 Firewall
Help with installing a sonicwall soho tzw no software.
Hello dlewis2900, What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
Sep 03, 2007 | SonicWALL TELE2 Firewall
Sonicwall tele2
Hello ask4jon, I gave this advice at an earlier time and I think it applies here to. What I want you to do is to reset your router by locating the Reset button on the back of the SOHO TZW next to the LAN connection. Using a pointed object, press and hold the Reset button for 5-10 seconds. All settings are returned to the factory default settings including the password and the default LAN IP address of 192.168.168.168. The I want you to reenter your ISP information and configuration settings. Once this is done try to ping your gateway (ISP gateway router) address. Then try to ping the internet try to ping this address: www.dslreports.com This is the quickest way to get back to where you want to be without trying to redo a lot of configurations.
May 29, 2007 | SonicWALL TELE2 Firewall
SonicWALL Pro 5060F Firewall Logo
1,066 people viewed this question
Top SonicWALL Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Alun Cox
Frank Zabroski
Frank Zabroski
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
