Question about Whirlpool Duet GHW9150P Front Load Washer
Cycle did not complete and F2 error code kept on flashing. How do you solve this problem?
  • 40 Answers
Drain pump issues take bottom front panel off 3 screws from panel and pull down then in middle you you will see the plastic housing of drain pump get towles ready there will be water that come out all that is in the machine unscrew cap in front of housing there will be something in the trap or in the impeller if problem still happens after you clear it out replace the pump
Posted on Mar 08, 2009
F2 error code flashes and machine wont finish the drain cycle
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
May 30, 2011 | Siemens WXLP1460 Front Load
It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely. Can you suggest any parts...
Welcome to FixYa.
The "F2" for Asko dishwashers indicates either the unit is overfilling, or the valve itself has failed.
The problem is likely the fill valve, based on your description... "It has been flashing an F2 error code and the timer starts at 65 then switches to "1" which stays on during the cycle. Now it will run for about a minute then stops completely".
Depending on the series of dishwasher you have, determined by serial number ( I don`t mean the model... I got it is a 1895 ) because those Asko machines had a revision to their valves moving from a dual solenoid to a single, the single substituting all dual coil valve units.
i.e.
The original Asko number would be # 8057508 and available at most brick & mortar parts vendors or on- line places such as "repairclinic.com".
** turn off the breaker at the service panel before servicing the unit...safety first**
To check the valve will require the removal of the lower panel/kick plate or also referred to as a toe panel, and with the aid of an ohm meter and at least one wire removed from each/the coil, measure the ohm value of the coil.
The valve will be on your right...
i.e.
It should not read infinite, but rather 0 to 93Kohms.
That should move you forward and hopefully solve the problem. Let me know if anything is not clear or if you require further assistance.
Thank you for choosing FixYa and good luck.
** If you have any reservation or are not completely confident servicing this unit please call in an authorized Asko technician **
These can be very difficult to service for one inexperienced, I see so-called pros mess them up all too often.
Regards,
Macmarkus :)
Oct 07, 2010 | Asko 24 in. 1895 Built-in Dishwasher
Sharp AR-163 Copier, How to Reset/Solve the error Code U2-40
how to clear red sing on tonal problem for sharp ar 163
Sep 16, 2010 | Sharp AR 163 Copier
We are getting a F2-41 code. How do we solve that?
1.Improper cartridge (destination error,life cycle error)
2.Identification error
3.model error
4.type error
5.destination error
6.data abnormality
7misc error
Feb 17, 2010 | Sharp Office Equipment & Supplies
My washer will not complete the cycle or drain the clothes. It just stops and beeps then flashes an error code like F2.
And F2 translates to: long drain. Make sure the drain hose from the machine is not kinked or plugged. Do you hear the pump running when it is supposed to? Check the drain-pump filter for debris. Replace the pump if it doesn't seem to run. Hope this helps!
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Dec 15, 2008 | Kenmore Elite 45986 Front Load Washer
Dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
Oct 26, 2008 | Dacor MCS130 Millennia Electric Single...
Error Code F2
That means the sensor that tells the computer what temp the drum (and the clothes) are so it can cycle the heater on or off according has failed. Please rate my help as solved if i answered your question! THANX
Oct 02, 2007 | Kenmore 84072 Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal De
