Question about RIM BlackBerry Curve 8310 Smartphone
Just goes dead... have to remove the battery and
Just goes dead without any warning...I have to remove the battery and do a re-boot...Why?
This problem just started 3 weeks ago and it has gotten worse. In the middle of a conversation the phone goes dead (black screen and all)
    Scholar:
  • 164 Answers
This sounds like a faulty BB or the battery is faulty. Try replacing the battery first if not then try latest firmware, if that doesn't work the new BB device.
I hope this Helps,
Thanks.
Posted on Mar 07, 2009
SHOULDN'T MY BATTERY LAST MORE THAN A WEEK
Do you mean that it goes dead after sitting a week or goes dead after a week while driving it?
Dec 23, 2014 | Cars & Trucks
The battery warning and anti theft light comes on and the car goes dead.
Check your voltage before jumping to the conclusion of a bigger issue. Get yourself an inexpensive multimeter/voltage tester and set it to 12v d.c.
1. Check voltage of just battery. Should be around 12 to 12.5 volts if its ok
2. Turn the car on, check voltage again, it should be 13 or more volts
If #1 is not happening, charge the battery overnight.
If you have a good charge and #2 is 12v or below, your alternator is shot, or you could have a corroded ground, loose ground, or something is just not making a connection.
If your battery keeps going dead after this, something is making a connection when it shouldn't and you have a slow electrical leak. If that's the case, start reading about how to check for voltage leaks in a car.
Dec 11, 2013 | 2006 Pontiac G6
Acer Aspire 7736z-4088 keeps shutting off randomly
Is the fan and vents free of dust? Is the laptop getting sufficent air flow? It sounds like power issues maybe multiple issues. Does it overheat? Difficult to say for sure. If your remove the battery?
Dec 01, 2012 | Computers & Internet
Acer 5315 will not switch on with power button, attempt then goes dead after 2 seconds battery light flashing amber when power lead connected but this is when power switched on or off. Sometimes it...
Try removing the battery and power on with the adapter. If you get boot, then you have a bad battery. If not then you adapter is more than likely not producing enough power to power the unit. You may also try allowing the battery to charge over night without trying to boot, If this doesn't do the trick, remove the hard drive and CD/DVD rom and one stick of memory. Try booting with just he adapter. Do the same with the other memory card and then swap memory slots and try again. If this doesn't produce a boot, you may have a broken connections in the laptop power connector. This will require a trip to a reliable repair shop.
Apr 09, 2011 | Acer Computers & Internet
I have a compaq nc6000 which wont boot up it trys to fire up then it goes off i have got to run but then it went back to this not booting up
Check and see if your DC connector is loose:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 02, 2011 | Compaq Presario Notebook
Low battery warning message on boot up
I'll give you the info for the cmos battery but afterwards observe any other issues with your notebook. Your notebook is not new anymore and may need other servicing besides a new cmos battery.
It should be housed driectly undeneath you notebook on a panel you can remove that houses the ram.
If you still cant find it, you may have to physicaly take apart the unit. I would search under the keyboard and all four corners of the motherboard and center. Just in case.
Let me know how it goes.
P.s: Be very careful If you are not use to opening up notebooks then I suggest taking unit to a professional for them to replace the cmos battery.
Mar 07, 2010 | Acer TravelMate 244LC Notebook
My Toshiba laptop screen shows 2 loading boxes then goes black
Perhaps this can help...
I have the solution for the non booting Toshiba that I wrote almost a year ago. This tutorial (written and pics from the repair of my m35) is applicable to laptops that shut down without any warning, laptops that turn on only sometimes, and laptops that simply refuse to turn on (LEDs blink, fan spins up for a second and then everything just goes dead). So if your laptop does not turn on, it goes completely dead within a few minutes after bootup, here's the link to the tutorial. The repair takes about an hour, there's no need of replacing any parts, reinstalling any software or any other thing. The only investment in repairing your laptop with this tutorial is your time. Basically, you can repair your laptop within the hour, without spending any money for any parts or software.
http://imateski.blogspot.com/2008/08/toshiba-satellite-m35x-motherboard.html
Mar 31, 2009 | Toshiba Satellite A105-S4254 Notebook
RIM BlackBerry Curve 8310 Smartphone Logo
426 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
