Question about HP iPAQ HX2490 Pocket PC
HP iPAQ 2490B can not be hard reset
I want to perform a hard reset but have no success using the reccommended procedure of holding in the calendar and iTASK buttons while pressing the reset button for 2 seconds. (It just gives a soft reset)Is there some other way to do it that works?
  • Ttap May 11, 2010
    you are releasing the buttons first then the reset, right?
    Problem Solver:
  • 8 Answers
If all else fails, remove battery from unit & let completely run down
(usually 12-24 hours), possibly longer.
Pop on charger, & unit should turn on as if hard reset
Posted on Jul 11, 2009
  • 4 Answers
Remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Posted on May 03, 2009
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
Tip
HARD RESET HP iPAQ h5000 Series 5450,5550 5555 HP h3800 Series 3830 3835 3850...
While holding down on the far left (calendar) and far right (iTask or Today) press in on the reset button (reset hole) with your stylus for about 2-3 seconds. After you see the screen fade, you can verify the hard reset by pressing the power button. If the device does not power on, then you have successfully reset you unit. To reactivate the battery you must either connect the iPAQ back to AC power or press the reset button again with your stylus
on Mar 10, 2010 | Cell Phones
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
How do i do a hard reset on HP ipaq X11-21204?
u have given a wrong Model number this is not a model number infact a part number pls try to find the correct model number from HP site thru photo identification if u dont find ur model other wise i am providing u detail below to try the hard reset on various series of HP IPAQS kindly be sure that ur ALL DATA WILL BE ERASED pls rate me FIXYA if i fixed ur problem
How to Perform a Hard Reset on an HP iPAQ
Performing a hard reset on an HP iPAQ is relatively easy, but is a dramatic step in the management of your handheld organizer. A hard reset will completely clear the memory of your device and restore it to the state you received it in from the factory. A soft reset, on the other hand, simply closes running programs and restarts your pocket PC.
Instructions
Difficulty: Moderately Easy
Step1
Read the owner’s manual. If you don’t have to do a hard reset, you shouldn’t, and you definitely don’t want to do one by accident. So familiarize yourself with the hard reset protocol offered in the manual.
Step2
Make sure you want to clear all personal settings, saved data and personal files from your PDA. If there are files you wish to retain, save them to a removable disk, or send them to your computer’s hard drive to be retrieved at a later date before performing a hard reset.
Step3
For the HP iPAQ h1900 series, hold down the power button while you use your stylus to hold down the reset button (on the left side of the iPAQ). Hold these buttons for a few seconds until the screen fades to black.
Step4
For the HP iPAQ h2000 Series, press down on the far left and right buttons (calendar and iTask, respectively). While you do this, press and hold the reset button on the back of the iPAQ until the screen fades.
Step5
For the HP iPAQ h5000 Series and H3800 Series, the procedure is the same as the h2000 Series with the only difference being on some models the Today button is used instead of the iTask button.
Step6
For the hw6500 Mobile Messenger Series and hx2000 Series the procedure for the hard reset is precisely the same as for the devices in step 4.
Step7
For the rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.
Step8
For the rz1710 and rz1715, follow the same procedure as the devices in step 7, with the difference of pressing the Today button (on the far right) instead of the iTask button.
Step9
To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Tips & Warnings
* If you’re iPAQ is simply slowing down or having problems, try a soft reset (reboot) before resorting to a hard reset.
* Read your iPAQ’s instruction manual to familiarize yourself with how to do a hard reset, and the effects of performing one.
* Do not perform a hard reset unless you are okay with or intend to erase all non-factory installed data and settings from your HP iPAQ.
Mar 17, 2009 | HP Computers & Internet
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
Rx1950 freeze on soft reset
You can do a hard reset by doing the following...
01) Press and hold down the "Calendar" and "iPAQ Wireless" buttons.
02) While holding down these buttons, use the stylus to lightly press the "Reset" button/hole on the back of the iPAQ until the screen goes blank.
03) Release the "Calendar" and "iPAQ Wireless" buttons.
04) Press the "Reset" button/hole again (so that it resets/powers on.)
Nov 01, 2007 | HP iPAQ rx1950 Pocket PC
IPAQ 5550
Performing a Full Reset A full reset is sometimes referred to as a ?hard reset.? Perform a full reset when you want to clear all settings, programs, and data from RAM. A full reset deactivates the battery. The power button does not function until the battery is reactivated. CAUTION: If you perform a full reset, your iPAQ Pocket PC returns to its default settings and loses all information that is not recorded in ROM. To perform a full reset: 1. Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the bottom of your iPAQ Pocket PC. 2. Hold all buttons until the displayed Full PDF document can be found here: http://h20000.www2.hp.com/bc/docs/support/SupportManual/lpia8006/lpia8006.pdf
Aug 19, 2007 | HP iPAQ H5555 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
1,644 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
