Hi My Samsung J1045 front loader has a squeaking bely and poor drive for the drum when full, how do I adjust? Mark
  • Anonymous Apr 17, 2009
    Having same problem, cannot turn heavy wet load of more than "three bath towels" hardly a big load! without squeaking,grinding and straining to even turn. Also experienced holes in clothes.! and wash never looks clean, have also noticed black scum. Very dissappointed with front loaders, will revert back to top loader. Never had so many socks dissappear since using front loader, explains why not turning I gather !
    I'd send it to repairers but the sheer weight needs three guys to lift rotten thing onto ute, so cheaper to buy a top loader., and it wont take all day to wash !!!! As for water saving - time taken to complete a load cycle - cost more in electricty to run......Lucky we're on tank water...
  • 15,935 Answers
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 14, 2010
My Samsung front loader dryer squeaks when running
The rollers at the rear could be worn
Dec 20, 2016 | Samsung Dryers
Started squeaking when washing ( 3 yrs old)
Bearings squeak, rollers that help rotation of the drum squeak, then lock up, and are eventually worn down by the rotating drum. If a front loader, removing the front door panel should let you see the coaster wheels that support the front of the drum. Maybe a little oil there would help.
Jun 01, 2015 | Washing Machines
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
I have a front loader samsung j1045.it just wont go on most cycles,so i was just using it on colours.now its showing the error de after a few minutes and beeping..please help?? Nan T
'de' stands for Door Error. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor. Both require a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
May 14, 2011 | Washing Machines
Can i use any drive belt on a front load samsung wasing machine model j1045
This is the belt number:
SAMSUNG FRONT LOADER DRIVE BELT 6602-001072 (1050323)
And this is just one source for the belt:
http://cgi.ebay.co.uk/SAMSUNG-FRONT-LOADER-DRIVE-BELT-6602-001072-1050323-/250632182892
Thanks for choosing FixYa,
Kelly
Apr 08, 2011 | Samsung Kitchen Ranges
Front loader iwll not start DE error code Samsung model J1045
this means door error sometimes you have to rewire it, replace the computer & the door interlock all at the same time to fix it try the door interlock first beware sometimes if you dont do it all at once the new part gets taken out as well so fingers crossed its just the door interlock.best option to have samsung service agent out to check out with diagnostic tools.
Jan 13, 2011 | Samsung WF337AA Front Load Washer
Lg front loader makes squeaking sound and struggles to spin
The drum is powered by a small motor and pulley, inside the unit and under the drum. A large belt wraps around the drum and pulley, and a spring "thing" provides tension so that the belt won't slip. The squeaking sound indicates that something is slipping, and the sluggish drum says that it's the drive belt. Take off the back, locate the motor/pulley/spring thing, and check the belt tension by observing the belt with unit operating. At that point you should easily locate the noise, at the motor (noisy bearing, lube or replace), belt warn (replace) or possibly the felt pads located at the top of the drum worn (not as likely but they do fail causing the drum to resist being spun by the motor to the point that the belt starts to slip. Hope this helps!
Jan 08, 2010 | LG WM1812C Front Load Washer
I can not seem to balace the washer- it dances around the room on spin. front loader j1045 6mths old
Has anything changed? have you moved it? is it level? Check the level of it and if it is infact NOT level make it so.. If it IS level I would not play with it.. get a warranty repair tech out..
Hope this helps
May 30, 2008 | Samsung Washing Machines
Door switch on my samsung j1045 front loader washing machine playing up, need another one please.. Ray.
I found a site that was not only free as it should be but has every jolly part under the sun and customer service as well. So naturally they instantly got my business.. Ray.
Apr 17, 2008 | Samsung Washing Machines
Washing Machines Logo
186 people viewed this question
Top Washing Machines Experts
