Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Pump/heat machine doesn't work - En2 message displays
I came out to my spa today and the pump has the message En2 listed...no bubbles go and I can't change the temp. Any ideas?
  • 3 more comments
  • Anonymous Mar 10, 2009
    My message says En1, and I also have no heat and no bubbles.
  • kgsick Apr 03, 2009
    Mine says En2 as well.
  • rcdupuis Apr 14, 2009
    I have the same problem, i called comfort line, and they said it is a build up of calicuim on the sensors, i asked on how to clean this and they would not tell me, instead said for me to get another unit. This the 3 rd time this has happened to me, i purchased a brand new power unit, paid approx. 700.00 for this, and it did the same thing after only 3 months. Now i have this 3rd unit with the same problem, and can't get it fixed.
  • scraper727 May 10, 2009
    They ****! I have now had three pump/heater units. Same issue every few months. They replaced it for me twice and now tell me it is my problem. This new unit says it is in OH mode (Overheated) and cuts out the heat. So now I have a 700 $ inflatable pool!
  • Anonymous May 20, 2009
    My unit shows en2 There is no way to turn on the heat or blower. This is my second pump unit. It's 1 year old and now just a pool. $700.00 down the drain....
En1 or OH means, your sensors are blind.This can happend
1) calcium, you don't use enough against it.
2) alga, you don't use enough chemical
3) acid, you don't have correct Ph value.
if you take care of the above issues, you never will have this code.
Posted on Nov 27, 2010
    Problem Solver:
  • 6 Answers
If you are seeing this type of error message there isn't any trouble shooting help to resolve this. You will need to have the unit serviced. Please call 888-997-6366
Posted on Mar 31, 2011
My spa is showing an OHH message. What is causing this message?
Make and model would help. How about my best guess?
OHH means OverHeated Heater caused by an error
One of the Water Temp Sensors has detected 118°F (47.8°C) In the Heater and Spa Functions are Disabled. You Must Press Any Button to Reset when Water is below 108°F (42.2°C). Check for Water Level, Flow Restrictions, Closed Valves, Air Bubbles, and Pump Prime, or Continue for a Detailed Test Procedure.
WARNING:
A Heater Overheat Error Message may indicate Excessively High Heater Temperatures which can Scald or Burn!
If the Heater is Not Cool Enough to Safely Service, allow the Heater to Cool before Continuing Testing.
A Heater Overheat Condition that generates an "OHH" Error Message is Most Likely the result of a Low Flow Condition. Therefore, "OHH" is considered to be a Flow Related Error.
Check for All of the following Conditions:
1.Low Water Level.
2.Blocked Suction Fitting.
3.Blocked Skimmer.
4.Dirty Filter.
5.Too Many Closed Jets.
6.Closed Slice Valve.
7.Heat Related Pump Not Running.
8.Heat Related Pump Not Primed.
9.Contact your Dealer or Service Organization.
DO NOT remove the protective covers from any electrical enclosure, or attempt to service any related electrical device, unless you are a qualified electrician or service professional.
As a responsible adult, always check the topside control panel display for errors and verify safe water temperature before using a spa, and before allowing children to use a spa. Safety should ALWAYS be your first consideration
Nov 15, 2015 | Pool & Spa
Intex purespa displays current water temp but will not turn on or start filter/bubbles. Bought 1 mo ago: just set it up a week ago. Was working fine for 1 week. TrI'd unplug and reset. Any ideas??
is displayed temp less than 2 degrees than setpoint temperature ? its possible this situation will disallow the pump to go to high speed and the air infusers to work till spa heats back up , or can be a heater fault as well
Aug 15, 2015 | Intex Pool & Spa
WHAT IS THE USE OF ROTARY PUMP ,DIFFUSION PUMP AND AIR ADMIT? HOW DO THY WORK ?
im gonna assume your referring to the parts that make a spa work ,
1st theres the main pump most times there centrifugal pumps with mechanical shaft seals , this pump moves water in thru the filters and out the nozzles around pool ,most spa's have a two or more speed motor that runs this pump
2nd some spa's (not all) have a second pump usually smaller these are for the heating circuits , they are also centrifugal and use mechanical or magnetic seals these pumps also intake thru the filters and push water thru the heating elements and also the water conditioner (UV) and on some spa's its also a means to add water treatment chemicals as well
3rd and last but not least theres the blower now not all spa's have one of these , but most do , this blower blows air into the main nozzles exit ports and make the wonderfull bubbles in the spa , now some spa's don't have a blower and use a process called venturi to draw air into a nozzle as water is forced out of it , but this type of system is a bit temperamental and is difficult to keep working well ,
blower motors also have adjustable speeds to adjust the amount of bubbles in spa
Jul 19, 2015 | Pool & Spa
Error code on pump oh, en2 , and n2 is repeatedly showing, turned pump off , changed filter , pressed reset and still the same error codes
Possibly a sensor, more probably a temperature sensor. But... For us to assist you, being more specific in your question is very helpful. Make and model?
Mar 19, 2015 | Pool & Spa
How to use Sino Spa spa controller pad
controls operate the pump to circulate the water..there are controls for bubbles and an air pump to increase the volume of the bubbles..and a setting to run the tub slower to allow heating of the water..
Dec 18, 2013 | Pool & Spa
The instrumentation panel says "SL" and the spa isn't heating.How do I get it to heat again?
You have it in "Sleep" mode. Spa will not heat normally in this mode...
If the SL Message is Alternating with the Water Temp in the Display Screen (we call this "Flashing Sleep"), the Spa is Operating in the Sleep Heating Mode.
If the SL Message is ON Solid (Not Flashing) in the Display window of the panel, the Spa is Operating in the Sleep Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Between Filter Cycles, while in the Economy or Sleep Heating Modes, the Pump has not turned ON and the Last Water Temperature is not Current. To read the Current Water Temperature, either Change to Standard Heating Mode or turn On the Heating Related Pump, and wait at least 2 Minutes.
SL or SLP is one of the Modes you can program your spa into:
EC - Economy
ST/Std - Standard
SL/SLP - Sleep
It is advised you keep your spa in Standard mode. Push the Jets button then immediately push the light button. Each press of the light button will scroll between these three modes.
Good Luck
Aug 27, 2013 | Balboa Instruments Duplex Digital Panel 2...
A downeast hot tub water is only 78 degrees turn up to 100 doesn't never get warmer and shows a ECn code
Check your filter cycles and switch spa into Standard Mode as you have it in Economy. (In Economy mode it will only heat during the filter cycles).
If the Ecn or Ec Message is Alternating with the Water Temperature on the Display, the Spa is Operating in the Economy Heating Mode.
If the Ecn or Ec Message is ON Solid (Not Flashing) on the Display, the Spa is Operating in the Economy Heating Mode, but there is No current water temperature because the Spa is between Filter Cycles.
Ecn or Ec is Alternating with Temp:
The Spa is Operating in the "Economy" (Ecn or Ec) Heating Mode.
The Water Temperature is Sampled Only during Programmed Filter Cycles. The Heater will Only operate and Heat up to Set Temperature during the Filter Cycles. The Water Temperature will probably drop Below Set Temperature between Filter Cycles. Other Heating Modes are Standard, Standard in Economy, and Sleep Modes.
Ecn or Ec is ON Solid (Not Flashing):
The Current Water Temperature is "Unknown" (- - - or - -) while in Economy or Sleep Mode.
Apr 06, 2013 | Washing Machines
Raypak spa heater pr5 service code message
check pressure switch if no voltage both sides of switch bad switch or plugged copper line or loose wires
Oct 02, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
977 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
