TATUNG 46'' LCD TV BACKGROUND IS GREEN W/ WHITE BLOTCHES
WHEN I TURN THE LCD T.V. ON THE BACKGROUND SHOWS GREEN WITH WHITE BLOTCHES. WHEN I PRESS THE MENU BUTTON THE MENU DISPLAYS LIKE IT SHOULD. WHEN I CLICK THE MENU TO THE BOX WHERE THE CONTRAST, THE SHARPNESS, THE BRIGHTNESS SETTINGS ARE. . .THE OPTIONS ARE GREYED OUT AND WON'T ALLOW ME TO MAKE ANY ADJUSTMENTS. BUT I AM ABLE TO PULL UP ALL OTHER MENU OPTIONS AND MAKE CHANGES.
ON 1 OF THE OTHER SETTING PAGES YOU NEED TO CLICK ON ADVANCED AND GO FROM THERE....
Posted on Sep 07, 2009
My Tatung plasma TV model no. P42hsmt when powered on shows green static no picture when changing channel screen turns to a strip of lines and returns to green spot static
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 07, 2015 | Tatung Televison & Video
I have green blotches on my Hitachi 42V710
Hello, I would take it to a TV repair place, they will charge around $50 and let you know what the problem is with it. this is your cheapest way out, it you want to keep it. If you chose to take it please give me a fixya rateing. Thanks, Farren
Dec 20, 2007 | Hitachi 42V710 42" Rear Projection HDTV
Shows picture for a second when i press button than goes dark
Issues with back light:
Please do not attempt to diagnose if no competent.
Do at your own risk.
Check for 24 Volts power to the inverter board
No Power---Check Power Supply
Power Present---
Verify status voltage 3v to 5v on inverter board harness (plug)
Replace Inverter Board
Feb 11, 2010 | Tatung V30DMTT 29.6 in. LCD Television
Tatung monitor Power light shows yellow light.
It sounds like your resolution or refresh rate is out of reach for your screen.
Restart your computer (even if it will be manually unplugging the power cable)
If you have no display while your computer starts up; you might have a hardware failure. Swapping your screen out, or plugging it into another computer (that works) will confirm if this is the issue.
If you can see the computer starting up you can press F8 (on your keyboard) continuously just before Windows can start.
Select "Safe mode" so that you will have the basics of screen settings.
Now you can go to control panel, display and click on the Settings Tab at the top. Change your settings to a rather default "1024x768" resolution and change your referesh rate to nothing more than 75hz under the advanced icon.
Hope this helps!?
Jul 07, 2009 | Tatung L17AMTN 17" Flat Panel LCD Monitor
Light goes green but no display.
Definitely Power Supply Board. Check carefully for open 1/8 watt metal film resistors. They wont show signs of overheating but they can be open anyway. I've never been able to find a print either. Once you do find open resistors make sure you measure for shorted components in the associated circuit.
Jun 15, 2009 | Tatung P46ACTP 46 in. Plasma Television
Burn-ins?
It sounds like your light engine is on it way out. I would have this verified by a service center. Very costly to replace. They will probably try a new lamp first.
Jan 21, 2009 | Sony KDF46E2000 46" Projection HDTV
Green blotches on screen
your vs and va need to be adjusted on power supply i can walk you through it but requirs volt meter and taking the back panel off tv
Jan 15, 2009 | Samsung SPN4235 42 in. Plasma HDTV
Tatung V30DMTT 29.6 in. LCD Television won't power on
bad power supply,common problem w/tatung,re-build power supply
Jan 04, 2009 | Tatung V30DMTT 29.6 in. LCD Television
Blotches on 20 in lcd
those blotches are where something applied too much pressure to the crystals and you can never fix it. they will look like a shadow for ever. won't hurt the working but looks terrible with a white background. Got kids?
Mar 08, 2008 | Televison & Video
Televison & Video Logo
175 people viewed this question
Top Televison & Video Experts
Electro Med Services...
