Question about Acer Aspire 2930-4661 Notebook
Can't drive monitor
Cannot use external VGA port to drive LCD monitor (Dell 1905 FP)
It doesn't work -- monitor says it can't display this resolution. i'm trying 1024x768. 1280x1024 both at 32bit/60Hz don't work
- I've updated to latest Intel 4500 GMA display drivers
- Restarting Vista gives same result
- I can successfully drive monitor at these resolutions/frequencies using another laptop
Any ideas?
    Scholar:
  • 82 Answers
Try moving the monitor down to a lower res. I would try 640 x 480 first and then go up from there. Also, some adustments may be required in displays for the second monitor....
Posted on Mar 07, 2009
I have a dell laptop that I want to add a second monitor to. My monitor is a HP L1755 and my laptop has Windows 7 Ultimate on it. I can not find a driver for this... any suggestions?
Hi there, if i read you correctly you are trying to connect external monitor on laptop. As you use old Monitor for this you can probably establish only VGA connection . For this you dont need any special drivers if you use VGA external connector on laptop. You just need to find out right combination on keyboard to activate external monitor to be activated or right click on desktop then properties and display option multiple displays. Of course when you manage to activate mode for external screen please use lower resolution like 1027*768 for second display aka monitor to test .Cheers
Sep 15, 2013 | Samsung 941BW LCD Monitor
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
Toshiba Satelite 105 4134 Major Resolution Problems
Sounds like your screen is going bad. It's either the screen or the video card inside of the computer, but most likely it's the lcd screen. Try connecting an external monitor to the laptop. You can Borrow a monitor from a neighbor, friend, relative or co-worker to connect to the laptop.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays correctly that proves your video card is ok and your lcd screen is bad. If the external monitor displays the same as your lcd screen then your video card has a problem. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 23, 2012 | Computers & Internet
I have got acer aspire net book size is 8.9 inch. Ca i connect it to external monitor
Hi.
Sure you can with a standard VGA video cable.
Maybe you will have to change your screen resolution to get the best display layout.
Hope it helps!
Feb 10, 2011 | Acer Aspire One AOA150-1784 Netbook
I have a Dell e1705; I had an external monitor hooked up when the LCD display died. I continued to use it with ext. monitor. However, now on re-boot it won't boot with external monitor unless I go the...
I think now problem is from Monitor side,Check with another monitor and also possibility of VGA driver problem,so reinstall driver for VGA.I think it helps. Let me know.
Jan 08, 2011 | Dell Inspiron E1705, Intel Core 2 Duo...
Want to connect my Dell laptop to my ViewSonic monitor-help!
Just connect the VGA 15 pin cable from the monitor to the VGA port on the laptop.
Turn on the monitor then the computer.
Hopefully Windows will find new hardware and ask you to run the multiple display wizard.
If the external display doesn't automatically turn on then you need to hit a keystroke combination. FN+ the key on the top row that has an icon that looks like a picture of a monitor. Usually an F key.
This keystroke combination switches between LCD, external Monitor and both.
When you get video on the external monitor, then you can get into the display control panel and change the resolutions and display modes to your liking!
Jul 06, 2010 | Dell Inspiron B130 Notebook
I broke my computer screen on my dell 1440 how i connect to a external vga monitor, i cant see the control pannel to set the resolution so the external monitor will work,, i droped the computer and i want...
You'll need to locate the VGA port on your Laptop to your monitor. The VGA port looks like ...
You should have a VGA cable that came with your monitor?
When you have connected the two together and turned on your Laptop the monitor should autosync and show the display. If this does not happen predd Fn+8 (the function key for external monitor support - should show a screen and a laptop on the key)
The Laptop may of course be damaged and not booting. Do you hear any disk booting? ... are the normal leds for keyboard etc lit?
Hope this helps, if so please leave feedback. If not, please let me know and I'll try and help some more!
Feb 02, 2010 | Dell Computers & Internet
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Dell latitude D610 and 1901 FP monitor
Did you hold down the Fn key and press the function key for the external VGA port? It should cycle as LCD only, LCD and VGA, VGA only and then back to LCD.
Dec 28, 2008 | Dell Latitude D610 Notebook
Acer Aspire 2930-4661 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
