It sounds like the carb needs cleaning. What type of machine is it so that I can assist you in cleaning it and also how old is the fuel that was in it?It sounds like the carb needs cleaning. What type of machine is it so that I can assist you in cleaning it and also how old is the fuel that was in it?
You can't post conmments that contain an email address.
Unhook your battery again for about 15 minutes. After you re hook it up, let car sit with the key in the on position, but not running. Let it sit for about 5 minutes, and then turn key off, and start it. It may run rough for a few minutes as the sensors and systems are all resetting. If you try running it right away, or cold, it can confuse the regen process
Hi there I once had a wee car,whenever it got too much petrol inside itself it refused to go anywhere and had to rest for some time and you had to be very careful with the choke and the petrol so it did not swallow too much of it and need another rest. kolbrun
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
