Question about Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range
Oven turning itself on
My maytag model mgr4452bdw is turning it self on almost caues fire
whats the problem?
    President:
  • Maytag Master
  • 2,651 Answers
Sounds like a short in awire or possibly the control panel, definatly not a normal issue and for sure is cause for alarm. i would strongly reccomend calling the manufacture and raise concerns for the safety of your home and moreimportantly your family, they take these sort of safety concerns VERY seriously(consider there position of liabilty incase of accident) ..
Posted on Mar 08, 2009
I have a black Maytag Gas Range stove the oven wont heat up. The ignition what i think it is, is glowing but when I tap the bottom of the stove it will light. What part do I need and where can I get it....
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
MODEL # MGR4452BDW SERIAL# 16419405NA The oven turns itself on and cannot be turned off with the digital controls. I have to unplug the oven from the wall outlet to turn it off.
their are two possibilities causing that,
1) bake or broil button on the touch pad has shorted out causing the touchpad to act as if it were being pushed to turn on.
2) a relay on the control board has shorted out and constanly sending power to the element
Gene
Aug 05, 2011 | Maytag MGR4452BDW / MGR4452BDQ /...
MGR4452BDW Maytag Gas Range. The oven will not heat up. The burners work fine. You set the temperature and hear a click, but never get heat or smell gas.
Hi Maureen,
Strange.. I just had the same problem with my oven tonight. I have the same model as yours.
Can you tell me if you were able to solve your problem?
You can e-mail me at gml07@excite.com
Dec 13, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a maytag mgr4452bdw gas stove.The top burners work fine but the oven itself will not ingnit.What could the problem be?
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Jan 27, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
The Maytag gas oven Model: MGR4452BDW and Serial:
Are you sure it's clean/ Does the smoke smell like wire burning or plastic? Is there a chance that there is some left over spill just burning off?
Jul 22, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
I have a Maytag gas range model MGR4452BDW. The control panel has fallen in on itself. How can this be repaired. It is 1 yr old
I repaired it myself. I took it apart and re-enforced the plastic with a strip of metal (where the screws are). It works fine now. Nothing wrong with the circuit board just the poor design. You have to push on the control pad for the oven to function and when the plastic breaks the panel falls in on itself. Plastic with metal screws and NO support behind the panel. A new circuit board costs at least $150 + tax + service call + labor. It probably would be better to buy a new range and all because of the poor design!!!
Jun 05, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Gas oven is starting by itself
You will have to replace the ERC. Electronic relay Clock.
Feb 22, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven
contact maytag and report this issue.I am doing the same.This is a serious matter.
Feb 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
Electriic oven control broken
maytag #mgr4452bdw the clock will not set the face reads 5-A-6 and the oven will not come on
Aug 27, 2008 | Maytag MGR4452BDW / MGR4452BDQ /...
Maytag MGR4452BDW / MGR4452BDQ / MGR4452BDB Gas Kitchen Range Logo
143 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
Sal DeAngelo
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
