Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
1997 gmc truck remote start system not letting truck start with in ,i un plug and it fires right back up,if i plug remote start in it wont start with key but will with remote ,i unplug remote key will start up ,any helpfull ideas etc. please help,email me at tazauger@hotmail.com
  • 344 Answers
Check the (ground out when running) wire going into the bypass modual, it may be shorted to ground keeping the unit on
Posted on Sep 29, 2009
  • 436 Answers
IF ENGINE CRANKS BUT NOT START -, sounds like a short in the tach wire, plug remote starter in and cut the tach wire to the engine for the remote starter. if the truck starts then you remote starter module is faulty.
IF ENGINE WON'T KRANK -, then there is a starter kill hooked in with it. if you bypass this you should be fine. just follow yellow wire from ignition switch till you find where it is cut. rejoin these two yellow wires and you should be good to go
Posted on Sep 01, 2009
  • devon obryant
    devon obryant Apr 24, 2014
    what if there was never a cord cut
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Truck wont start no fire replaced everything execpt the brain for timing could that be the reason it wont fire
If you messed with the timing its probably out of time for the reason it will not start
Aug 30, 2014 | 1997 GMC Suburban
Fuel pump runs but wont start
Check spark at the plug and lead Check coil pack or module in distributor if fitted.
Jan 05, 2014 | 1994 GMC K1500 Door Mirror Fits SIERRA,...
1997 volkswagen golf, runs good then bogs out and stalls when ideling
Check condition of spark plugs, fuel filter and air filter.
Check condition and/or replace plug leads.
Strip clean and inspect idle control valve.
Report if no fault found.
Nov 07, 2012 | 1997 Volkswagen Golf
My 1997 GMC Sierra 5.0 Litter wont start and i changed the fuel pump regulator, what might be the problem?
engines need 3 things to start (petrol engine)
fuel, air and a spark,
as you have been working on your fuel system it is best to suspect this system first,
on engine turn over see if you can smell fuel at the exhaust.
if you smell fuel the fuel regulation mybe too high and the engine is flooding.
if you do not smell fuel, remove fuel line from engine and ensure fuel is getting to the engine,
(be careful not to let fuel spill this generates a fire risk)..
once fuel is getting to the engine, check your ignition system to ensure you have a good spark to ignite the fuel.
finally check your air filter is not blocked and that you have air getting to the engine.
I hope this was helpful.
Jan 11, 2011 | 1997 GMC Sierra
1997 , wont crank
if starter will engage and engine can turn over quickly it should start.
however.. i dont know how you are verifying it has fuel as its a high-pressure FI system.
these systems by GM are VERY finicky and unless within spec precisely it will NOT run. i suspect fuel pump is putting out less than 57# which is min for these.
fuel pump known failure part. if replaced you MUST also replace wire harness at tank as they usually fail internally w/melted wires you cant see through wire sheath. low voltage will KILL the new pump.
also you didnt note engine size and family...
Sep 11, 2009 | 1997 GMC Jimmy
1997 jimmy wont start
Check ground cable
Feb 05, 2009 | 1997 GMC Jimmy
97 jimmy wont start
If it starts with starting fluid, this means the firing and electrical is fine,however, its not getting fuel. I suggest trying the fuel filter first,but, its probably going to be the fuel pump.
Dec 29, 2008 | 1997 GMC Jimmy
97 gmc sierra died wont start
sound like you are not getting the right fuel pressure you need to check the fuel pressure hit the tank in the center with a hammer and se if it runs if it does you need a pump
Nov 29, 2008 | 1997 GMC Sierra
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
313 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
