Question about GE WJRR4170E Top Load Washer
GE topload washer occasional screeching noise during wash cycle
When the machine is in teh wash mode occasionally a screech nosie comes from the "transmission"? I can see the drive shaft turning it looks fine, belts are fine, but the noise sounds line it is coming from teh HUB teh sahft passes through. Teh noise is not constant, but random.
It sounds like it could be a brake pad that has broken and is partially rubbing against the brake frame.
Posted on Mar 07, 2009
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
The drum is not spinning during washing or rinsing
Idler pully is the usual problem. The two tub roller will usualy make knocking sounds but can make squeling nosis.
Jun 06, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
A screeching sound during agitation cycle only.
sounds like a bad clutch. check the transmission out for ware and inspect the clutch as well. make sure the brake is not dragging as well.
May 22, 2009 | Maytag Washing Machines
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Screeching noise!
hello mam
when the belt or bearing are worn out you will be getting this noise please check it.
Mar 31, 2009 | General Electric WHDSR316G Top Load Washer
Majic Chef 400
HI i think you have a transmission problem. expensive to fix
Sep 07, 2008 | GE WBSR3140DW Top Load Washer
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
GE Model WHDSR209D2WW makes unbearable loud metal Screeching noise
ppr78, couple of things you want to check. The bottom panel on these GE's are pretty flimsy. I have run into a couple where during agitation the bottom of the motor housing would rub against the bottom panel making a terrible noise. You need to remove the front panel by pusing on the clips on the left and right side just under the top. The front panel will pull out. During agitation, take your foot and push down on the bottom panel and see if the screech goes away. I have also found the suspension rod support sockets at the top dry out and make a screeching noise. You also want to check your belt and pully and see if the noise is from there. Check these things first...Catriver..post back.
Jan 12, 2007 | GE Profile Prodigy WPSE4200A
GE WJRR4170E Top Load Washer Logo
433 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
