Question about Locks & Locksmithing
How do you reset the combination for a Burton cable lock for snowboard/skis?we can't remember the code and it is unlocked now. we don't have the manual anymore thanks.
  • 28 Answers
SOURCE: We don't remember how to unlatch the actual
Here is the instruction sheet:
http://www.masterlock.com/pdfs/5400D_Instructions_Sheet.pdf
Posted on Oct 07, 2011
SOURCE: brinks fire resistant safe model 5059 instruction manual
To bad you dismantled. Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
Posted on Sep 16, 2008
Bajanguru
  • 7752 Answers
SOURCE: unlock code
do the hard reset *2767*3855#
Posted on Dec 27, 2008
AmrSabri
  • 59 Answers
SOURCE: samsung J400 forgot privacy lock code,i want to unlock
Hello lovechat1,
Remove the sim-card and switch on the phone .. and press this code *2767*2878# .. the phone will restore the factory settings.
Thank you for using FixYa.
Posted on Apr 09, 2009
SOURCE: I lost the instructions to reset the combination for two luggage
I lost the combination lock
Posted on Jul 12, 2009
Where can I buy ski and snowboarding gloves?
You can buy ski and snowboarding gloves at the main manufacturers' store (ie. The North Face) and other local stores, as well as online in many different websites such as: http://www.backcountry.com/ski-gloves.
Feb 06, 2013 | Winter Sports
Tip
How to wax your snowboard for travel
before flying to a ski holiday do not scrape your wax from the bord
scrape only when you start to sku
on Jul 07, 2010 | Burton P1 Snowboard Bindings 2008
What are the main manufactures of ski and snowboarding gloves?
The main manufacturers of ski and snowboarding gloves are The North Face, Burton, Dakine, and Marmot.
Lost combination for bicycle master lock. It has 229T sticker on it.
If you can remember an numbers in the combination you will just have to try all other numbers in combination until it opens
Apr 30, 2011 | Master Lock 8143DSG Combination Cable Lock...
Both of my burton triad bindings highbacks are broken. Where can I get new ones?
Go to www.trusnow.com
Used to be Sierra Snowboards, I just had a look and they have them for $189.95.
http://www.trusnow.com/Burton-Triad-Snowboard-Bindings.asp is the link straight to the product.
Good luck.
Jan 30, 2011 | Burton Triad Snowboard Bindings (Men)
The locks work fine when there's no gear loaded, but when i put my boards onto the rack the locks won't turn. any suggestions?
sounds like a pressure issue ( binding problem ) --- when you go to lock the locks ( with the skis and/or snowboard on rack ) try and push down hard on the rack while you turn the locks,, this might get the pressure off enough to allow the lock cams to pass. if this does not work then the next thing to do is to file down and modify the lock cams so they turn easier without binding. if you do not have the tools to do this modification then you can always go down to your local locksmith shop ( with the skis/snowboard on the rack ) and have them do the modifications -- the shop will only charge you around 10 to 15 dollars for this service.
I hope this helps,
c...
Jan 25, 2011 | Yakima Fat Cat 6 Ski and Snowboard Rack
I forgot my password, how can I reset it.
Via Da Kine FAQ's:
Q: I have forgotten the combination to my Cool Lock, can you tell me what it is?
A: Unfortunately we do not have the capabilities to know what you chose as your original combination.
Best bet would be to write down numbers that have significance to you since you set the combination originally and try various combos or if all else fails brute force it. Turn on some TV pull up a comfy seat and get to work finding one of the possible 1,000 combinations.
Dec 28, 2010 | Da Kine Dakine Cool Lock Ski Or Snowboard
I hav a Burton Audex link jacket. I have a problem with the audex system. The control panel automatically switch to discoverable after aprox 10 seconds of turning it on then won't access the menus again....
id check the cables, they may be damaged, try it with the jacket flat on the floor. ive gone through 4 jackets all with bad wiring, unfortunately Burton doesn't have any more warranty replacement jackets...
Nov 14, 2010 | Burton Audex Pi Mp3 Mens Xl Pimp Snowboard...
Broken cable on BOA lace system on snowboard boots
i just recieved a new lacing for my Rocky revolver boots... there is a little tool to loosen the set screw in the knob...works like a charm.
Feb 28, 2010 | Burton Winter Sports
Locks & Locksmithing Logo
2,718 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
