Question about Sub-Zero 632 / S
Subzero 632 cycles from 37 to 50 degrees
Cycles up and down
  • 71 Answers
Few things to check... condenser coil clean. dirty condenser fluctuate temp. clean condenser. evap fan motor work? open the fridge. press the switch. heard the fan? feel the frame around the fridge an freezer is hot? or cold? cold ok. hot dirty condenser coils OR condenser fan motor. or seal system problem. call a tech>.. good luck... LEAVE YOU COMMENT IF IT WAS GOOD FOR YOU... thanks
Posted on Apr 02, 2010
When was the subzero 632 made?
Are you asking when was the first one made, they were in production for several years you can use the serial number to tell the date of manufacture
Sep 05, 2014 | APW Wyott SubZero Refrigerator Freezer...
I need subzero 632 shelving?
I need a serial number and which shelf do you want to replace so I can check to see who has it and where. The serial number is important and all subzero unit and design changes only accrued in some parts. Get back to me and I can search this for you and you can call Subzero direct to get the same information I could. Either way, I am willing to assist you if you want. Thanks..
Aug 25, 2014 | Refrigerators
Subzero 632/f vacuum condenser still flashing after cleaning
Yes it would be in the drying cycle which goes for almost an hour after the final rinse
Jul 15, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
My door on my subzero refrigerator squeaks really bad. How do I fix? Model 632
Spray a bit a WD-40 on the hinges and then wipe off the excess...give it a couple of days to work into the hinge...
heatman101
Sep 11, 2010 | Sub-Zero 632 / S
Subzero 632 no water in ice maker ,water supply fine to fill valve,how do you ck valve?
you can check continuity of the valve coil or cycle the icemaker. check the fill tube to the icemaker and make sure it's not filled with ice.
May 22, 2010 | Sub-Zero 632 / S
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
We have been getting service code 50 for our SubZero -- it;s a 690 model fridge/freezer. I cleaned everything however over last three weeks the error repeats. I reset the board by pulling power from the...
Error code 50 means excessive refrierator section compressor run. Possible causes include: dirty condenser, stopped condenser motor, faulty termistor or an evaporator refrigerant leak. If it is a refrigerant leak it usually shows up as frost or water driplets half way down on the back wall. Clear codes by holding the alarm button in for 15 seconds.
Aug 26, 2009 | Sub-Zero 632 / S
Subzero 632/s won't cool also frost build up in fridge
you have a leak in the evapator you will have to call a subzero tech to get it changed..
May 03, 2009 | Sub-Zero 632 / S
Sub-Zero 632 / S Logo
529 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
John Tripp
John Tripp
Steve
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
