Question about Singer 7444 Mechanical Sewing Machine
Hi I am pretty sure that the bobbin and the thread are in correctly but when I put the material in the needle just put holes in the material. what am I doing wrong?
  • 26 Answers
You may have adjusted the upper tension and made it so tight that the thread just pulls out of the needle and needle makes holes in fabric. you might want to check the feed of the bobbin, it will not allow the machine to sew if it is not able to be picked up by the needle. the bobbin thread is usually (when held in your hand) with the thread coming counter clock wise. and then it will lay in the bobbin holder and the end of the thread will come back to about the slide catch thing and be held there until the needle thread catches it (leave the cover off the bobbin area until you watch and see what happens then. Try adjusting the bobbing tension too hope you understand what I mean here.
Posted on Mar 08, 2009
Upper thread is not pulling lower thread from bobbin up through sewing hole
increase the needle thread tension up more the tension is correct when the threads meet at the middle of the material being sewn
Mar 14, 2016 | Singer 2250 Tradition
I am having great difficulty getting my machine to draw up it's bobbin thread - I am pretty sure I have threaded it properly but nothing is happening HELP PLEASE!!
Hi Kate
No Mention of Brand or Model
Meanwhile
Go through whole procedure again.
Use different thread just in case
Take bobbin out
Re Thread it
Put it back in (well seated)
Hi Kate Ware, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
Jul 08, 2015 | Sewing Machines
How would to insert the bobbin in the sewing machine brother VX 1400?
There is not much of a secret to inserting a bobbin in a sewing machine. A couple of things to check, the thread from the bobbin should be pulled through the slot of the carrier, and make sure the thread comes through the sewing hole by manually lowering the threaded needle and then lifting it out of the hole again after it has picked up the thread from the bobbin. The video link posted below is useful if you have a Brother sewing machine.
If the stitching is still not right then check that the needle is fully inserted in its housing. (Push the needle up as far as it will go then tighten the screw.)
How to wind and install the bobbin and thread the sewing machine PART 2...
Aug 24, 2014 | Sewing Machines
Help with Euro Pro 9000, the thread keeps getting tangled up in the bobbin area..
When I had this problem, even though I have been sewing for years, I was just not threading the needle properly. Make sure the presser foot is raised when you thread the needle. Another reason is that the thread is too old, the needle is not the correct size or type for the material, neither is the thread. Hope this helps. It's usually nothing to do with the bobbin, but the upper thread.
Jul 11, 2014 | Euro-Pro 9000 Mechanical Sewing Machine
Upper thread gets jammed in bobbin area
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Dec 12, 2012 | Brother Sewing Machines
When I embroider, the back of the material gets enormous knots in the thread. What can I do to fix it?? Thank you!!
change the needle
check to make sure the thread has not come off the thread take up lever
change the thread on top & bobbin area
clean under the needle plate & bobbin area for loose threads or lint
check to make sure the bobbin is not warped
check to make sure there are no burrs on needle plate
make sure the bobbin is wound correctly & inserted correctly
Aug 11, 2011 | Brother Sewing Machines
My machine won't stitch, and the tensions seems to be very high, even after adjusting it.
Hi, if your bobbin has thread, check to make sure the bobbin is inserted into the shuttle correctly. If it is loaded correctly, check to see if the needle is able to pull the thread through the throat plate.
If it doesn't have thread, then all your sewing machine will do is make little holes because the bobbin thread is what catches the sewing needle thread to form the lock stitch to sew the material together . Check your manual on the sewing machine for where it is and how to put thread into it.
Feb 25, 2011 | Juki DDL-8700
The bobbin thread keeps getting matted up and pulling the material in the bottom... I'm using a heavier thread, and have tried several differant kinds of material to see if that was the problem...
Be sure to use the correct thread, advised in your manual and that your bobbin and top threads are not too different or else you will have problems. If, you are using a real thin material, try putting tissue paper under your fabric so that it won't get caught. in the needle hole. Usually matting under the fabric is caused by incorrect threading but I am suspecting your thread itself. If, you don't have a manual, go brother-usa.com and download one for free.
Sep 13, 2010 | Brother XL-2600
Bobbin area will not work
There should be a spinning cover with a hook that fits over the bobbin. Normally, you just pull the bobbin thread out through the swinging/sliding plate hole. Turn the machine by hand toward you (at the top) until the needle dives into and comes back with both threads. Separate the threads and assuming that the thread tension above the needle is set correctly, feed a piece of material in to see if it sews correctly. The tension is set so that the thread is even on both sides of the material. Let the machine pull the material through at it's own pace, your function is to guide the material.
Jul 17, 2009 | White Sewing White 3032
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Singer 7444 Mechanical Sewing Machine Logo
200 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
