Question about Tomtom RIDER GPS Devices
Pls describe the size and type of security screw on tomtom RIDER
Can anyone describe the size and type of security screws that hold the tomrom rider case together?
The internal part of the power connector has broken and topmtom will not repair as out of warranty!!
It is probably an easy repair if I can find the right type of tool to unscrew the case. Then I can get inside and replace a common electrical part.
I have nothing to loose anyway as tomtom will not repair.
Please provide answer if you know?
Alan Ferguson
I have tomtom rider 1.
There are 3 sizes of Torx screws; 3 sets of 2 screws each.
The largest is at the top back. I watched a fellow on YouTube take the back off. That was very helpful.
Someone called that T6 screw. I found a little set of security torx drivers for this.
The 2 bottom corner screws are smaller and then inside that on each side of the door are 2 more (smaller size but longer) screws.
Then carefully take the back off. There are wires connecting the back to the main board.
Take the card out before you try to take the back off.
Hope it works ok for you.
Ron
Posted on May 26, 2009
How do you remove the speedometer and tachometer from the housing of a 2002 harley davidson low rider
Hi Anonymous, remove 2 screws that secure the console, revove 4 screws that secure gauge bracket, unplug gauges. Have nice day.
Apr 20, 2013 | 2002 Harley Davidson FXDL Dyna Low Rider
Harley Davidson 2006 FXDLI Dyna Low Rider fuse box
Hi Anonymous, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 11, 2012 | 2006 Harley Davidson FXDLI Dyna Low Rider
My tomtom rider 2 will not turn on
My tomtom rider 2 will not charge on my bike and will not charge from mains electric, when i use my tomtom in the car it works.
Cheers Tim
Mar 23, 2011 | Tomtom RIDER GPS Devices
Fuse box on 02 low rider
Hi Strange7daze, on a Dyna all fuses, circuit breakers, relays, and modules will be behind the left side panel cover secured by grommets, four nuts or screws. On later models the electrical panel bracket cover secured by four nuts or screws must also be removed to gain access to electrical components. Good luck and have nice day.
Jun 14, 2010 | 2002 Harley Davidson FXDL Dyna Low Rider
I turn on my tom tom go 700 and the screen appears with a picture of the tom tom in a green box and then it stops and i wont turn of
If your TomTom GO/ONE/RIDER is frozen, won’t turn on or does not behave as it should, it can be fixed by resetting or restarting your TomTom device.
A reset will not delete any data from your device, with the exception of SMS messages on TomTom GO500/700.
  1. Connect your GO/ONE/RIDER to the power charger. If you have a power charger, use it to power your TomTom GO/ONE/RIDER. If you do not have a power charger, make sure that the battery in your TomTom GO/ONE is fully charged.
    Note: You need to charge your GO/ONE for at least 2 hours using the 12-24V cigarette lighter adapter.
  2. Reset your GO/ONE/RIDER. To reset the unit, you simply have to push a straightened paper clip (or something similar) into the RESET hole on the device.
    • On TomTom GO 910/710/510, the RESET hole is located on the bottom of the device.
    • On TomTom GO 700/500/300, the RESET hole is located on the bottom of the device with the word RESET right next to it.
    • On TomTom ONE, the RESET hole is located on the bottom of the device, with the word RESET right next to it (just below the SD card slot).
    • On TomTom RIDER, the RESET hole is on the bottom of the device, behind the SD card door. When opening the SD card door you will see the RESET hole on the left, right underneath the SD card slot.
  3. Your TomTom GO/ONE/RIDER is now reset. Finally, press and hold the power button for 2 seconds.
Dec 16, 2009 | Tomtom GO 700 GPS Receiver
Connector
I would be enclined to reccomend the Garmin product for GPS..
Built better,, better mapping and better all around product..
Sep 14, 2009 | Tomtom RIDER GPS Devices
Tomtom Rider GPS won't turn on
My Rider 1 is showing the same sympton. Was working fine now I can't get past the initial "Tomtom" screen.
Does it power up when connected to the mains charger?- No, need to prod reset and then turn on manually.
Does it switch on when connected to the bike cradle? - No, only sign of life if by manually turning on but only get as far as the Tomtom screen, not the main menu.
Any ideas welcome
Jul 14, 2009 | Tomtom RIDER GPS Devices
Need tomtom rider 2 2nd addition docking shoe
Forget TomTom. Go buy this one
http://www.wunderlichamerica.com/mm5/merchant.mvc?Screen=PROD&Store_Code=WA&Product_Code=8600880&Category_Code=
I talked to TomTom multiple times on the phone and had same problem but finally found this. It's better quality and it's available.
Mar 24, 2009 | Tomtom RIDER 2nd Edition GPS
Tom tom rider
I made a video on how it open your TomTom rider.
Feb 09, 2008 | Tomtom RIDER GPS Devices
Tomtom RIDER GPS Devices Logo
404 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
