Question about Toshiba Office Equipment & Supplies
We replaced the toner cartridge in our estudio232 copier yesterday. The machine worked fine yesterday and this morning, this afternoon it is saying we need to replace the cartridge. I opened the cartridge area door made sure the cartridge was installed properly. The machine made noises and displayed loading toner, then went back to the display replace toner cartridge. What is wrong??
  • frank386 Mar 09, 2009
    This morning the repairman was here. When the cartridge was installed, someone forgot to remove the seal, therefore no toner could come out. seal removed, problem fixed.
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; that's toner motor defective , replace it! the parts no. is
41309035000
Posted on Mar 08, 2009
Am looking for toshiba E studio 232
Cartridges have ink/toner? Cartridge bad?
May 26, 2016 | Toshiba E-Studio 232 estudio232
My Kyocera FS-C2126MFP is saying that the toner is improperly installed
NEVER use aftermarket or refilled cartridges in your printers.
Dec 05, 2013 | Office Equipment & Supplies
Printer is just printing a whole page of black ink and no words
Yqes that is your toner. It needs to be replaced or checked if needs to be replaced mmaybe needs cleaning asking but for the most part. If only black ink and no colors do a self diagnostic on the printer , if this is not available make sure there are no paper jams also.
Feb 21, 2012 | Ricoh Office Equipment & Supplies
How do you reset the toner sensor after replacing the toner it says it isn't full.
you should ONLY replace the Toner cartridge when the machine tells you to. NOT when it says replace "soon". If this has occurred..the fuse in the cartridge was blown prior to the time that the cartridge should have been installed. Now the machine is asking for a new cartridge but the fuse has already been blown. Contact a Muratec SERVICE rep if you are unable to replace the fuse yourself.
Jul 15, 2011 | Muratec MFX-1430 Copier
I have e-studio 355, machine is indicate low toner. I replaced new toner cartridge but the machine show "toner not recognize". I try to replace the ic at the back of the old toner cartridge and...
Do not go very far yet, the problem is with the toner so I recommend you do what the machine says before looking somewhere else. replace with correct toner.
If you have a friend with the similar machine which is working properly try and get their toner put in your machine if it works buy similar toner if does not then it is the machine. You can also try your unrecognized tone in another machine see the results. The problem is just toner and the sensors in your machine.
Jul 14, 2011 | Toshiba e-Studio 205 Copier
I PUT A NEW TONER AND IT IS SAYING THERE IS EMPTY
Are you sure it was a full NEW toner cartridge?? Not an old one you had lying around.
If it was a new one the next question line goes as follows.... the machine will say in the display to "Rplace toner soon"...that dosn't mean its empty and to replace it..that means itsLOW and you should have a new toner cartridge "on-hand" because it will soon stop printing and say "REPLACE TONER". At that time the toner cartridge should be replaced, when it is installed a "fuse" on the cartridge blows and resets the toner light on the display. If you installed the toner cartridge when the display was saying "replace toner soon" you have blown the fuse in the new cartridge, now the machine has run about another 100 copies and says "replace toner"....but you now can't reset the light because the fuse is already blown because you may have replaced the cartridge too early!!! WHAT CAN YOU DO if that is the case...you can replace the fuse on the cartridge..its pretty easy to see, just replace it with another mini-fuse of the same rating written on the existing fuse..then put the cartridge in again..the fuse will blow, reset the light and away you will go. When all else fails read the operators manual.
Jan 23, 2011 | Muratec MFX-1430 Copier
I have a Brother MFC-7440N machine. On 7/22/10
The toner cartridges have a small port on the side that the printer uses to check the toner level. Our 7440N tells us it will soon need a new toner cartridge and will then print another 400 copies. Search YouTube for Brother Toner Cartridge and it will show you how to modify the cartridge by covering up the portholes with tape. Since there is obviously some kind of sensor, you might need to get a can of air and clean out any extra toner. Lastly, the Brother cartridges have "reset gears" which are replaced when the cartridges are refilled. You might have a cartridge which the gears were not replaced on.
Jul 26, 2010 | Brother MFC-7440N Laser Printer
Copier says replace toner cartridge but cartridge has been replac
The "chip" was necessary to "reset" the electronics inside the refilled cartridges, to say that the cartridge has been refilled. Obviously, the chip did not properly do the "reset".
Your only hope: take the document, as a PDF file or a Microsoft Word document, copied to a USB memory-stick, to the local "big box" store, e.g., Staples, or Office Depot, and let them read the file from the stick, and print onto their printer.
Feb 02, 2010 | Sharp AR-M277 All-In-One Printer
Screen says drum near end
Drum for Brother MFC-6800 All in One Machine
You can expect it to print 12,000 Page Yield
Whats the difference between a DRUM and a TONER Cartridge? The toner cartridge is a cartridge holding the toner (ink). The drum does the work to transfer the ink to the paper. You will need to replace the drum every 5-6 toner cartridges you use.
Sep 24, 2009 | Brother MFC 240C All-In-One InkJet Printer
Toner life end
Try this:
Open the cover, leaving everything inside. Press Options, then *00 to reset the fax.
If that doesn't work:
Open the front cover and remove the cartridge and drum. Turn off the fax. On the right-hand side of the cartridge, there is a round hole that is covered with a clear plastic or glass. Cover that hole up with tape, put the cartridge back in the drum, and put them back into the fax, and turn it back on.
Dec 05, 2008 | Brother IntelliFax-2820 Laser Fax
97 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
