Acer Aspire   PC Desktop
Problem for Acer Aspire (AST180-US340B) PC Desktop
Locked out of my admin. account
By babi_doll103 on Mar 07, 2009
i changed my password on my administrative account i dont remember it now.
Solution #1
posted on Aug 17, 2009
Not Rated)
zpowx2
Rank: Master
Rating: 77%, 33 votes
You can DIY a password reset disk. Download windows password unlocker from http://www.passwordunlocker.com/products/wpu.html, there is an .ISO image file integrated in the windows password unlocker. Burn the .ISO file onto a blank CD with your favorite burners or use the freely burner included in windows password unlocker. With the newly created windows password reset disk, you can reset windows admin password with our erasing anything else
Was this helpful?
Yes
No
Solution #2
posted on Jun 10, 2009
Not Rated)
adhude
Rank: Wiz
Rating: 90%, 87 votes
use this cd to reset the admin pass....burn to a cd...boot the cd and select the partition where your windows is installed...and the password will be reset
http://rapidshare.com/files/226200662/cd080802.zip
Was this helpful?
Yes
No
Solution #3
posted on Apr 24, 2009
Not Rated)
Alexis xy
Rank: Master
Rating: 78%, 274 votes
Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} . Long time ago , I confronted with the similar problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's worth a try!
http://www.resetwindowspassword.com
Comments:
Apr 24, 2009
- Long time ago , I confronted with the similar problem. Finally , my friend Jane introduce the Windows password Reset.It help me access windows. It's worth a try!
Was this helpful?
Yes
No
Solution #4
posted on Apr 22, 2009
Not Rated)
getbackwindo
Rank: Guru
Rating: 88%, 23 votes
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
Was this helpful?
Yes
No
Solution #5
posted on Mar 07, 2009
Not Rated)
krhtechy1
Rank: Wiz  Computers & Networking  Expert
Rating: 85%, 51 votes
In the future, you should make a password repair disk from the accounts panel in control panel. There is a backdoor solution if it is XP. Follow these instructions very carefully....
1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
  • Go to the Control Panel and open up User Accounts.
  • Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
  • This will initiate a wizard.
  • Click Next and then insert a blank formatted floppy disk into your A: drive.
  • Click Next and enter your logon password in the password box.
  • Click Next to begin the creation of your Password disk.
  • Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Note: If your computer is part of a domain, the procedure for creating a password disk is different.
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire PC Desktop
Questions and Unsolved Problems for Acer Aspire PC Desktop
Do you recommend Acer Aspire (AST180-US340B) PC Desktop?
Answer
Answer
computerwillnotstart up
Answer
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX... (More)
Answer
id number ybsko14335 will this computer connect wireless
Answer
I installed Rosetta Stone and got the error 2123, is this a driver problem?
Answer
Using EasyCapDC60 with Ulead Video Studio 10.0. After a lot of probs(partly solved by using mic jack... (More)
Describe your PC Desktops problem:
Related Products & Issues:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktop Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(646) 202-3935
Macbook LCD Screen Replacement $159 iPhone 3g...
NYCiPodDoctor 877-TUNEDOC (8863362)
Chat Now
Insert Link
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Step 2: Select a product and click on add
I can't find my product
select
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Send to: (e.g. Julie@email.com)
(Separate email adresses with commas)
Your name:
Your email address:
Message:
