Question about Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door
Gas fireplace won't light up even when pilot light is on
The gas fireplace was brand new in 2006, used only a few times and then turned off completely and never used again for at least 2 years. Now I'm trying to use it. The pilot light is on, but I couldn't get it to burn/light up. What could be the problem?
Thanks!
  • 2 more comments
  • maylilyann Mar 08, 2009
    Thank you for your quick reply. I did turn the knob to the "on" position and even adjusted the dial to "high". It didn't work. Then again, I haven't used it for at least 2 years. You think I should get it serviced then, or is there anything else I should do at this point?
  • Richard May 11, 2010
    After you re-lit the pilot, did you turn that control knob to the "on" position (fully counter clockwise)? That is the most common oversight I encounter when I go on repair jobs. If you did and it's still not working, there could be a blockage in the main burner feed which is preventing the flow of gas between the burner and the control valve. Another possibility is a bad thermopile.
  • Debra Baker Oct 08, 2012
    I was having the same problem and richiestar's suggestion worked for me.
  • JoeF Oct 31, 2012
    I had the same problem too. It worked for me as well. Thanks Richiestar
Check for how clean the bottom of the unit is. I know it seems small but when dealing with these amounts of electric current they are just that "small" and the dust can be shorting out the unit and not allowing the gas valve to release the gas. Its a safety thing, they dont want gas around an electrical short "go figure" lol
Posted on Jan 05, 2010
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Burner will not fire
If you could answer a few questions I may be able to help.
Is there a thermostat hooked up to this fireplace?
Is the gas valve turned from pilot to on?
Is this a millivolt system with a powerpile?
Let me know and I will try to help you out.
Jan 12, 2014 | Procom Dual Fuel Vent-Free Fireplace with...
Pilot light 5301
The Skytech 5301 does not control your pilot light. That is a function of your fireplace's valve. Complete instructions for lighting your pilot can be found in the owner's manual of your fireplace, or at the brand's website.
The 5301 should not need to be reset in any way. Once your pilot is re-lit it will operate normally.
If you need a new copy of the 5301 manual, it can be found at the bottom of the product page here: Skytech 5301 fireplace remote.
Mar 16, 2013 | Skytech 5301 Fireplace Remote Touch Screen...
Fireplace burner won't stay on
try cleaning the pilot sounds like its a short pilot and when the burner comes on it pulls the gas from the pilot light .
Feb 22, 2013 | Heating & Cooling
Napoleon Fireplace propane Pilot won't light main burner even though gas flows in?
  • I'm going to assume your fireplace has a pilot light.
  • Follow the little holes in the burner that lead to the pilot light.
  • Make sure the pilot flame is pointing directly at the closest burner hole. (adjust if necessary).
  • Often, you will need to sprinkle a layer of "glowing embers" in this area. The embers will help the gas travel to the pilot light and ignite.
  • Always start your propane appliance on "High" never "Low". Cold propane likes to drop to the bottom of the firebox and accumulate until it reaches the pilot (this is called delayed ignition). Keeping it on "high" will help the fuel travel over to the pilot without buildup.
Jan 21, 2013 | Napoleon 36" Zero Clearance Top/Rear Vent...
Our ( unknown brand ) used gas fireplace pilot light will not stay lit. As long as you hold the lighter to the pilot light and push the knob ( in the pilot lighting possition) it will stay lit, but as soon...
The magnet inside the gas valve is probably gone or simply has corrosion. Remove the thermocouple from the magnet at the base of the safety valve. Do not remove the magnet it is not serviceable. Clean out the hole with a pencil eraser. Reinstall the thermocouple and retry. Getting a gas valve will be a task unless yall can find another used fireplace. Most of time corrosion buildup causes the problem. The probability of the thermocouple itself being bad is slim because they are very well built.
Let me know.
Nov 20, 2011 | Heating & Cooling
Temco DV6400N fireplace will not turn on. Pilot
Do you have a remote that turns the unit on and off
and has different heat settings? Could be the batteries are bad in remote
Jan 02, 2010 | Heating & Cooling
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
Propane fireplace insert won't light
Gas apliances have safety features built into them so you don't blow yourself up. The pilot heats a thermocoupler which tells the gas valve there is a flame, open the main gas to the burner. If you can see the flame area of the pilot look for a round post about 3/16 inch in diamiter. This should be directly in the flame, if not bend the bracket so it is in one side of the pilot flame. The thermocouple is attached to a mounting bracket. This will be held in place by a 1/4 inch hex screw. remove the screw and the capilary tube leading to the gas control valve. Before you do anything, close the main gas supply to the fireplace and disconnect the power to the fan. You may need to semi dismantle the fireplace to get the thermocouple. The gas valve end is a brass 1/4 pipe thread plug. Turn the outer nut and remove without twisting the tube. Reverse this order to install a new one. Besure not to twist the capilary tube, tighten brass nut 1/4 turn past hand tight. Your better heating supply house will have these in stock. Restarting the pilot will take a few tries because the gas was off. Your gas suplier would charge about $75 to fix this. if you don't have the proper tools and it dosen't look pretty stright forward don't do it. You could get dead.
Dec 01, 2008 | Heating & Cooling
Napoleon 36" Zero Clearance Top/Rear Vent Natural Gas Fireplace with Black Door Logo
10,814 people viewed this question
Top Napoleon Pool & Spa Experts
John Rodgers
John Rodgers
Craig Butler
Craig Butler
Paul Carew
Are you a Napoleon Pool and Spa Expert? Answer questions, earn points and help others
