Question about AOC Envision L32W461 32 in. LCD HDTV
Aoc tv L32W761 won't "find" digital channels
When we go to auto program this tv no digital channels are being found. it says our signal is "normal" Help!
SOURCE: W The VGA cable doesn't work/AOC L32W761
I finaly just read te manual on my netbook (go figure) And I was able to toogle over to the external monitor, by hitting <fn> F5 key.
Posted on Nov 29, 2008
SOURCE: digital - Weak or no signal digital coax when hdmi dvd player on
if u have placed your DVD next to your tv ... just maintain distance between then and check out
Posted on Apr 01, 2009
SOURCE: Unable to tune my LG Electronics Digital TV (Model 37LC2d-ec) to receive digital channels (have tried auto and manual program). TV will only receive basic standard channels. TV bought in Uk - now livi
My LG plasma TV 50pc3d when power-on only see vertical bars. what 's going on. please help. Thank you
Posted on Jul 22, 2009
  • 108 Answers
SOURCE: Have TV AOC L32W761 When i turn it on light turns
This sounds like a problem with the power supply. Usually capacitors on the power supply board tend to dome, bulge or dry up. The damaged ones can be seen on the power supply circuit board when the back is removed. The dry ones have to be removed and tested. The caps can be replaced at a repair shop for around $200, but if the power supply board has to be replaced it can cost a little more. It all depends on the shops repair fees.
Posted on Sep 07, 2009
SOURCE: No digital channels after running auto search
Same thing with my vizio vx37l tv. Did you fix the problem bpakja? If so please let me know how.
Posted on Dec 10, 2009
I've lost the remote control for my AOC Envision L32W761. How can I change the menu and input source options using the front panel controls? I'm able to access the menu screen but can't figure out how to...
Try navigating the screen using the volume and channel controls. If you still can't get to the left side of the screen then try press the menu button again while on the menu screen to see if it'll navigate you there.
Hope this helps :)
Apr 20, 2014 | Envision L32W761 32 in. LCD TV
No channels are located by Auto scan by AOC
Analog TV is pretty much dead. It is unlikely that you will find any analog channels. Search only for digital channels.
Apr 07, 2014 | AOC Televison & Video
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
AOC LCD27H060 won't find channels
Check your antenna cable connection. Check the center wire of the connector to ensure it is not bent.
Apr 29, 2012 | AOC LC27H060 27 in LCD TV
I have a 32" AOC Envision L32w761 LCD hdtv with no
There are only two things that can cause this problem -inverter and T-con. Since you have already replaced the inverter, it can be nothing other than the T-CON or LCD controller. Replacing the same should resolve the problem. On a side note the inverter/T-Con problem can be isolated easily. The purpose of the inverter is only to light up the backlight of the panel. So when it fails you will still have a faint picture that can be seen if you flash a flashlight on the screen. If you would like me to find you the replacement T-con let me know the part number and I will get you the link to the part.
Sep 07, 2011 | Envision L32W761 32 in. LCD TV
What is the comcast remote code for aoc envision tv L32w761
Directly from Comcast.com
AOC 3,010,017,025,044
Hope this helps.
Aug 27, 2011 | AOC Envision L27W461 27 in. HDTV LCD...
Only analog channels now. AOC L32W761 T.V.
old digital tuners in TV (like 2007 and before) failed a lot in my experience. This is possibly your problem.
Jun 07, 2009 | Televison & Video
Nov 28, 2008 | AOC A20S431 Television
AOC Envision L32W461 32 in. LCD HDTV Logo
757 people viewed this question
Top AOC Televison & Video Experts
Raj Patel
Are you an AOC Televison and Video Expert? Answer questions, earn points and help others
