Question about Logitech Webcam
Blurry pics i have a logitech quickcam and i've turned the focus ring and diddled with colour, lighting and nothing makes the pic clearer. PLEASE HELP!
  • 87 Answers
Did you make sure the lens was clean? Wipe lens off the reset the webcam to its default settings. Slowly adjust the focus ring for best effect then adjust the video settings.
Posted on Mar 08, 2009
It is extremely blurry
Rotate the ring around the lens to adjust focus
Make sure you have Microsoft DirectX 9 (+) installed
Check your USB sockets are 2.0 (enhanced ) or use a powered hub
Fine tune the image in the Settings menu ( 2 gear wheel pic ) on the Logitech webcam toolbar
Aug 05, 2010 | Logitech 961462-0403 Webcam
I just bought a logitech C250h web cam and the picture is blurry how do I fix it?
Check
1) If the webcam has a focus ring around the lens to sharpen the image
2) if your computer has the necessary powered USB ports for this model
3) Launch the logitech dashboard (toolbar) start the cam using the Quick Capture menu and adjust while running using the Settings Menu
May 21, 2010 | Logitech Quickcam IM 961361-0403 Webcam
My logitech webcam is blurry how do i fix that?
Some webcams have a focus ring around the lens that you rotate others rely on the software for a good focal length
Launch your Logitech toolbar from the desktop or from 'All programs'
Click on the 'Quick Capture' menu (2 photo frames picture) to start your webcam.
With the webcam running click on the 'Settings' menu (2 gearwheels picture)
Here you can adjust all your settings to achieve the best image
Apr 12, 2010 | Logitech QuickCam Pro 9000 Web Cam
I have a logitech quickcam v11.7 and it went blurry what can i do
On all webcams and also on other cams you have a ring around the lens. This ring is meant to focus the camera on to the object. start the webcam and rotate the ring. Clockwise and anticlockwise. Whichever direction get you to a focussed image, stop there.
Aug 30, 2009 | Logitech QuickCam Chat Personal Web Camera
Focus is always somewhat blurry and never sharp. Help!
Well just telling you this is a very easy thing to do so twist your lens cap right or left it would make your view much clearer
Jun 22, 2009 | Logitech QuickCam Pro 9000 Web Cam
The image is blurry and doesn't focus.
I believe the ring around the eye moves and will focus.
Apr 25, 2009 | Logitech QuickCam Communicate Deluxe...
Focus
The little white ring on around the lense, that is the focus on the camera. Now the other issue with picture quality is the camera itself. I believe this camera only 1.3 mega pixels to get a less blurry higher quality pic u should use a higher mega pixel camera
Nov 12, 2008 | Logitech Quickcam Chat Webcam
Pic quality
Many factors can affect the image quality of your pictures. If you are experiencing blurry images, please try adjusting the focus ring located around the lens. This will allow you to focus the camera image on objects at different distances. Also, make sure there is good lighting. Improving the lighting conditions can improve the image quality considerably.
Connection Issues:
If the image quality is poor while transmitting video over the Internet using video enabled programs such as MSN Messenger, Yahoo! or AOL Instant Messenger, your connection speed to the Internet directly affects the image quality of the transmitted video. Corporate LAN, DSL/cable modem connections will result in the best image quality experience, while dial-up connections may result in choppy and overall poor quality because of the slower connection speed. Even broadband connections such as DSL/cable modem may experience choppy video at times because of Internet traffic or slow upload speeds. If the image appears clearly in the camera software, most likely your Internet connection may be responsible for the poor image quality in your video program.
Changing Display Adapter Settings:
If you are still experiencing a distorted, fuzzy or grainy image, you may need to change the settings for your display adapter. For optimal image quality, please make sure the video display adapter is set to display at least 16-bit high color or higher. To change the color palette please perform the following steps:
  1. Click on "Start," "Settings," and "Control Panel."
  2. Double-click on the Display icon.
  3. Click on the tab labeled Settings.
  4. In the dialog box labeled Color Palette, verify the video mode is set to 16-bit (high color) or 24-bit (true color).
  5. Also, check with the manufacturer of the video card for updated video drivers.
Low Light Boost:
If you cannot do anything to improve the lighting situation, some Logitech video cameras have an option for "Low Light Boost." If there is an option for "Low Light Boost," try enabling the "Low Light Boost" in the QuickCam software. To do this:
  1. Open the QuickCam software.
  2. At the bottom right hand corner of the camera image box, click on the arrow next to the QuickCam icon.
  3. Choose "Advanced Camera Settings".
  4. Under the Image Enhancement box, place a check mark in the "Low Light Boost" option.
  5. If that does not improve the image quality, try adjusting the other image settings, such as contrast, saturation brightness, gain and white balance.
  6. Click OK when your are done.
Using Latest Software:
Finally, make sure you are using the latest release of Logitech camera software. You can download the latest release from the Logitech Downloads + Parts page.
Feb 26, 2008 | Logitech Webcam
Blury Pictures
My Logitech Quickcam for notebooks Deluxe webcam was blurry.
I spent 3 hours surfing the net looking for the answer, only to find a load of vague and technical responses about OS's and other ****. I fiddled about with the focus ring around the lens on my cam, which wouldn't move, so i figured i had an inferior version that had some sort of in-built auto-focus.
Eventually i lost my rag with the poor quality of information i was finding on this issue.
I went downstairs, got my pliers out of my tool bag, and wrenched the lens ring.
It moved.
Camera focused.
Job done.
Voila, no techy **** required.
Feb 16, 2008 | Logitech Webcam
Logitech Webcam Logo
91 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
