Ethernet cable un plugged
I have gone thru the connections severl times and connection repair and keep getting the same answer ethernet cable un plugged. I have checked and rechecked and done everything that I have read to do but can't get on line. I installed a linksys wireless adapter and it says it is working and signals are strong.
    Scholar:
  • 164 Answers
If your wireless router has a strong connection then is your Laptop trying to connect to the correct Connection. Sounds like your talking about Fixed ethernet connection?
How many connections have you created in the "my networks" area?
Let me know,
Thanks.
Posted on Mar 07, 2009
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
Desktop pc windows 7 sp 1 wired cisco dpc 3008 no additional devices random connections
I would first get a new Ethernet cable and try it. If that doesn't fix it, call your cable company and have them do a diagnostic from their end. They can tell if it is their equipment or not. It their modem is OK, and the Ethernet cable is OK, then your LAN (Ethernet) card is either going bad, or possibly not completely inserted in the socket. To check: turn off and unplug your PC. Take the side off, look where the Ethernet cable goes into your computer. If it is on the motherboard, you may want to get a LAN card and use it instead of the onboard. If the cable goes into a card plugged into one of the slots, make sure it is fully inserted. If it is, you may want to get a new card.
Oct 28, 2017 | Cisco Linksys DPC3008 - cable modem
I have gone to numerous forums and IT friends for support but to no available...nothing at all. My problem I would think not to diffucult but obviously it is. I have a Gateway 560GE running XP. Modem...
When you use USB for networking the "Network" it is on is 10.10.0.1 or similar, Now the Ethernet is 168.192.0.1 or similar. You simply MUST enter the correct address if you wish to change anything. Use the Connect to the Internet wizard and ensure you choose correct net, address. & if you have two Nic's Ethernet & USB, you must make sure you choose right one too.
Feb 07, 2010 | Toshiba Slim Port Replicator II
How to connect the lancable and what is the
color code? just go get a standard ethernet cable (straight thru, patch cable) and plug it into the ethernet port on your computer and the modem.
Dec 07, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
Ethernet connection problems!
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed.
then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 06, 2009 | Linksys WRT54G2 Wireless Router
Cant go wireless
I think the problem is not your laptop configuration. Can you check the setup configuration of the router it's maybe the wireless function is disable. Or try to reset the router to his default configuration. Press the reset bottom of the router for 15 second then try to connect your wireless connection if still not working setup again the router configuration.
thanks
Apr 15, 2008 | Belkin (F5D5231-4) Router
Modem not working right
Do you have both an ethernet and a phone cable connected to either your modem or your computer? If you have an ethernet connection, there is no reason to keep the phone cable connected. They are competing. Remove the phone cable and you should be fine.
Oct 19, 2007 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
