Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Dryer wont start, but sounds like it wants to
Checked the belt and it was fine. Not sure what else to check.
  • 27 Answers
CHECK THE DOOR SWITCH AND REPLACE IF NEEDED
Posted on Mar 08, 2009
What is wrong with my washer, started washing clothes, it filled up with water and then nothing. Checked belt it was fine, wanting to know is it the fuse or does the knob need changed.
The timer mechanism has gone south and needs replacement since it is not activating the cycle. To confirm hook up the motor directly to the power line and see if it runs.
Jun 22, 2015 | Washing Machines
We have a Brissell 12amp preheat pet shampooer and the roller on the bottom are not turning we checked the belt but it seems fine. so we're not sure if there should be 2 belts or one . and what would be...
Bissell Proheat has two belts. A stretch belt goes from the motor to the pump and a geared belt goes from the pump to the brushroll. Both belts should be replaced once or twice per year.
Oct 23, 2013 | Bissell Vacuums
I have a affinity dryer that just humms when I turn it on. I have power 220 at recpt. no code reading?
Sounds like the motor could be locked up, Is the dryer turning if not belt broke , Check belt, take the front access plate where the motor is located and turn it on check to see if the shaft of the motor is turning at normal speed and again check the belt, with power off and belt is not broken by hand turn the drum to make sure nothing is blocking it from spinning freely. if that is free and clear than my bet is on the motor itself as it sounds like it is in locked rotor.
Cause's of locked rotor
Motor seen its better days
if equipped the start/run capacitor could be out
Hope this helps.
Mark
master Electrician
Sep 19, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryer worked fine yesterday, started it today and the display turns on, push button to start, it beeps (like it usually does) and nothing happens. No sound from the dryer at all. I thought maybe the belt...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 14, 2011 | Dryers
Dryer will not turn on. Was running fine, opened door with 10 minutes left in cycle, put in another load to dry and it wouldn't turn on. Checked to make sure door was closed, checked breakers, made sure...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Oct 21, 2010 | Dryers
Dryer will come on but drum won't turn, checked belt it seems to be fine, motor makes a humming sound
heatman101
Oct 11, 2010 | Frigidaire GLEQ2152ES Electric Dryer
My mate has a 2002 lancer .had the timing belt done and all electrics checked and a full service done..also had the plugs changed.it starts fine but when its warmed up it runs like its on 2 cylinders.
i checked the engine at gates.com, a manufacturer of timing belts. the '02 lancer is listed as an interference engine. that means if the belt broke while the engine was running, you might have some damage to the valves. also if it is slightly out of time, the problem could occur. you must make sure the timing is spot on, which may require going back into the timing belt and checking crank and cam position. you may also have to tear the valve train down and check for damage
May 19, 2010 | 2002 Mitsubishi Lancer
Kenmore 90 Series Dryer started to operate very loudly. The noise sounds like it normally does while drying, just much, much louder than usual.
I would think the belts are getting bad need to be checked anyway, also while your checking the belts check the tenision pulley for the belts make sure it has not fallen off, also, make sure dryer is LEVEL, hope this helps let me know please thks larry
Feb 27, 2010 | Kenmore Dryers
Whirlpool dryer model number WED5300SQ0 wont start
take a meter and check door switch then if good take the back off and check all thermostats,thermal fuse,AND if your belt is off theres a safety switch on the idler pully.hope this helps
Nov 15, 2009 | Whirlpool WED5300S Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
