Question about KitchenAid KGSA906PSS Gas Kitchen Range
Kitchenaid KGSA906PSS gas slide in
I'm afraid to use the self cleaning feature after reading this....SO, can i buy oven cleaner that's safe for self cleaning ovens and just do that?
  • 27 Answers
GO TO THE WEBSITE TO GET THE PROPER
INSTRUCTIONS FOR YOUR UNIT AND WHAT
CLEANERS CAN BE USED FOR YOUR UNIT.
Posted on Mar 08, 2009
Kitchen aid gas range model kgsa906pss. After using self clean oven door is locked and control panel is out. There is power through the thermal fuse. What else should I check?
Try unplugging the unit for about 10 minutes and then plugging it back in. If the problem persists call for service especially if under warranty.
Apr 11, 2014 | KitchenAid KGSA906PSS Gas Kitchen Range
I have a kitchenaid ykess907ss00 i start the self kleen but i open de door at the same time now the light inside stay on and im not able to start the self kleen he tell me close the door
Hello there and welcome to Fixya
Ok here is the thing about the self clean features on these ovens the self clean feature is programmed in the ovens computer memory so when ever the self clean feature has been interrupted it needs to be reset
The only way to reset this is to first unplug the oven and leave it sit for at least 1 hour (without interruption) now after the full hour is up plug in the oven and you may hear a audiable beep if so simply press the cancel button and you should be able to nw open the door or get back to what you were trying to do ok ?
So please try this and post me a comment on how this works if there is more help that is needed i can continue to help you on this ok?
Best regards Michael
Dec 15, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Gas Self Cleaning Oven: When we tried to use the "self cleaning function" of our oven a "F5 E1" code was displayed. According to KitcheAid this indicates a "Latch System...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 26, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Did a self clean now display will not come back on and oven wont open
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Aug 12, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
My self cleaning oven doesn't stay on and the message says f2 e1 what's wrong with it
I would suggest never to use the self clean feature. The oven gets so hot that it will burn up some of the components. I did this and it burnt up a ten dollar sensor. After calling a repair man and haveing it fixed it ended up costing $500.00
May 18, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
E3F3 on kitchen aId Model KGSS907SSS00 while self cleaning
doorlock will not disingage after self clean cycle is through
Mar 20, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
KGSA906PSS Kitchenaid slide in gas range. I just used the quick self clean and the display went black and will not come back on and the door is locked.
The thermal switch was bad. I removed the sheet metal back from the oven and there is a small round part with two wires one on each side. You replace it and bingo the door will open and display will come back on. If you do not have he part you can touch the two wire together and the stove will unlock.
Nov 28, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
Oven shut down
Please call directly to KitchenAid/Whirpool and speak to the 'executive management team' - when I spoke to them they said this wasnt a common problem, they were not aware of the fault.. EVERYONE with this fault please call again.
Replacing the fuse each or not using the self clean function is not a fix!
Jul 20, 2008 | KitchenAid KGSA906PSS Gas Kitchen Range
KGSA906PSS
Took me almost three months to get a new range, and kitchenaid still insist it is an "isolated incident"... They need to be exposed and sued...
Aug 17, 2007 | KitchenAid KGSA906PSS Gas Kitchen Range
KitchenAid KGSA906PSS Gas Kitchen Range Logo
192 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
