Question about Acer Aspire 9300-3642 Notebook
Acer 9300-3642 will not boot up. I put it in sleep mode before I left this morning. Come home and will not boot. - The power light does come on. - I don't hear any sounds of the normal boot up process happening when I try to get it back on. - I took out the battery and unplugged it for about an hour. What am I missing?
  • 4 more comments
  • Snow Mar 07, 2009
    I have not reseated the RAM or Hardrive.
  • Snow Mar 08, 2009
    The battery light is now on and the CD light does blink when I first turn it on. I usually hear a CD "boot up sound" after that but I don't hear that now.
    I'm not sure how to take out the main battery...going to look up a diagram right now.
    I've never removed an AC before but if the first steps you suggested don't work I'll try to figure that out.
    Thanks so much for your time!
    *Snow*
  • Snow Mar 08, 2009
    By the way, I did remove the hard drive and booted up as "cheap to fix" suggested, left the battery out and then plugged back in. That didn't work.
    Going on to the next suggetion but thanks for trying! Appreciate it.
  • Snow Mar 08, 2009
    Oh Ok! Got your comment about removing plug. ;) Working on all that now. Looking for instructions on how to remove main battery yet. I see the two little "connectors" black and white...I assume I pop those off somehow but looking to make sure.
  • Snow Mar 08, 2009
    Ok I completed all your suggestions and still nothing.
    I need the Waaahmulance! Am I screwed?
  • Nicholas Lussier May 11, 2010
    Hi, have you removed and reseated the RAM or Harddrive
  • 64 Answers
I would suggest pulling out the backup battery, main battery and AC adapter, then hold the power button in for about 10 seconds, reconnect your batteries / AC and try it, if that does not work remove the AC / ram and harddrive then reseat them, then plug it back in and try.
Does the battery light show that it is charging when plugged in? Do you notice if the cd drive lights up when turned on?
Posted on Mar 07, 2009
  • Nicholas Lussier Mar 08, 2009
    Sorry, by remove AC i meant unplug it.
    Master:
  • 404 Answers
Remove the hard drive, and power on
  • lotfi bouakaz
    lotfi bouakaz Mar 08, 2009
    yeah pop out, wait 20min put back in
  • lotfi bouakaz
    in this case your motherboard is faulty.
Acer one with windows 7 ultimate fall into sleep mode
A laptop computer is typically set to conserve battery power. One of the common settings called standby, sleep mode or hibernation turns off power to the screen and the laptop itself after a preset time limit passes without any mouse or keyboard activity. It can be inconvenient for the computer to shut down while you're working on an open page or during a download. Change the setting if you don't want your laptop to going into automatic shutdowns
Turn the laptop computer on with the power button if it's not set to turn on upon opening. Allow the system to boot up. Open the panel for adjusting the sleep settings. This varies among the popular versions of Windows operating systems. To change the sleep mode setting on a laptop running Windows XP, click the "Start" button, and click the "Control Panel" selection. Choose the "Performance and Maintenance" selection, and click on "Power Options." Click the "Power Schemes" tab, and click the drop downs next to "Turn Off Monitor," "Turn Off Hard Disk," "System Standby" and "System Hibernates." Select "Never" for each drop down in both the "Plugged in" and "Running on Battery Power" columns. Click the "Hibernate" tab and click to remove the check mark in the box next to "Enable Hibernation." To change the sleep settings on a Windows Vista laptop, click "Start," "Control Panel," "Systems and Maintenance" and "Power Options." Then click "Change Plan Settings" under the currently established plan. Click on the "Advanced Settings" tab and select the "Never" option on the "Sleep," "Sleep After," "Hibernate After," "Display" and "Turn off Display After" drop downs. Click the "OK" and "Save Changes" buttons to confirm the settings. To change the sleep settings on a laptop running Windows 7, click the "Start" button, choose "All Control Panel Items," select "Power Options" and click "Edit Plan Settings." Click the drop downs for "Turn off the Display" and "Put the Computer to Sleep." Choose "Never" for both and click the "Save Changes" button.
Feb 06, 2013 | Acer Aspire One PC Notebook
M15x gaming laptop screen wont come on after sleep mode or reboot. What can I do?
Looking at your last comment, it looks like you got it working??? Just an heads up, in the future, you might not want to put your laptop into sleep/standy mode while performing an update. If you lose power or have to do a hard shutdown you could corrupt the update and your PC might not boot back up.
Jan 09, 2013 | Dell Alienware M15x Gaming Notebook
Monitor will not power on
The monitor has entered permanent sleep mode. After four years of service, it probably is not worth repairing
Oct 21, 2012 | HP W2408H 24-inch Widescreen LCD Monitor
Acer3000 yellow light solid and will not power on Help! Is this motherboard issues?
It's very possible you have motherboard issues. Hardware failures will often resemble the machine being stuck in "sleep mode". You can try a power "reset" in case it is stuck in sleep mode. Press and hold the power button for 30 seconds. If successful, the machine will boot (probably in safe mode) and you should be able to re-configure your power settings to disable sleep mode. If this doesn't work, you most likely have hardware issues and the motherboard is most likely the culprit.
Aug 20, 2011 | Acer Computers & Internet
Ma acer aspire 5738z does not atart at all. the power on led nd the on/off buton light glows but the scree remains black. when i last left the comp i put it to sleep nd it went 2 sleep after installing new...
sounds like sleep mode created a conflict while downloading updates.and your pc is still in sleep mode..about the only thing you can try,is reinstalling everything..may work may not
Oct 16, 2009 | Acer Aspire 5735 Notebook
Acer Aspire ZG5 Power Led showing yellow
Hibernation is the biggest creator of software nightmares...it has killed more computer systems and corrupted more systems than I can count. Go to control panel > power options and change your power settings in there. Turn hibernation off and just have the computer go to sleep after a certain time. You will find that the computer will come right back in sleep mode and will be ready for action. Don't worry about the system running until sleeping and then waking up, it's a lot better than finding your entire operating system is now corrupt and has to be re-installed.
Sep 15, 2009 | Acer Aspire One PC Notebook
Acer Aspire 3610 stuck in sleep mode
When you turn on your laptop do you see the P.O.S.T screen or it just remains blank? and also while booting up do you get any beep sound?
Try to boot your computer in Safe Mode by Tapping F2 (or Del in few laptops) key after pushing Power Button.
let me know what happens.
Askari :)
Mar 27, 2009 | Acer Aspire 3610 Notebook
Aspire AM1201 does not boot up.
hi im josh in cebu phil. try to enter bios set up.go to power menu.then try to change the setting of power loss to shorter time then save the changes then restart your pc. good luck.try to txt if problems continue.
Feb 16, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Acer Aspire 9300-3642 Notebook Logo
252 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
