Question about E-Machines (T2824) PC Desktop
EMachines 2824 not powering on
I have an eMachines T2824 and the unit is not wanting to power on. I have swapped the PS but it is still unresponsive. What else could it be?
    Scholar:
  • 157 Answers
You can check also by removing the boards.you can check the mainboard outside in the box..you remove the mainboard and check if the mainboard is not shorted with another devices.
Posted on Mar 07, 2009
Flash player
just go on the net and ask for flashplayer download make sure you pick the free one.
Apr 06, 2014 | E-Machines (T2824) PC Desktop
No power supply power out, ps fan not coming on, fuse is good
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Dec 30, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
T2824 emachine turning on and off by itself. Sometimes it will be on for a 3 or 4 hours and go off and then turn its self back on in a couple hours later or even the next day come back on. I replaced the...
Take the side cover off and use compressed air to clean the dust off the heatsink fins atop the processor. If that doesn't help, take any cowling off, and make sure no dirt is plugged between the heatsink fins.
Feb 15, 2018 | E-Machines (T2824) PC Desktop
My computer won't turn on. I cleaned the Air spinner thing, checked the mother board, and everything was fine. The computer is an Emachines T2824. Can i have some assistance on how to get it to turn on?
If the machine is doing nothing at all when you press the power button, chances are your Power Supply Unit (PSU) has failed. If this is the case, the only way to fix it, is to get a new PSU.
Nov 03, 2010 | Computers & Internet
E Machine ATX 250 -12E replacement PS
With emachine MOBO's you have to make sure you plug in the 20 pin plug from the power supply to the mobo. Also make sure all hard drives, cd/dvd roms, floppy drives, etc are turned on. Make sure the red switch on the PS is set to 115. Make sure the PS is plugged into a known working outlet. Make sure MOBO is properly in place with all grounds/screws in place and nothing metal near or touching board which may short it out.
You can review the E Machines PS replacement guide here for further instruction.
Good Luck,
Jesse
Jan 11, 2010 | Gateway Emachine Bestec ATX-250-12E PS...
I need hepl with setting up the bios on a T2824 Emachine
Hit  f 8 when starting computer. When you get into the BIOS setup screen choose the default settings. Find the start priority and put the cd driver first.
Jan 24, 2009 | E-Machines eMachines Desktop PC
EMachine T2824 does not turn on. Power cord/power supply seems O.K.
There are just too many eMachine models to be familiar with every one, however, as a preliminary inspection, remove the side panel, and turn the computer on to see if you see a green "Health" light. This will give you an initial clue as to how to pursue the problem. eMachines have historically had power supply problems. If you do not see a green health light on the motherboard, then your power supply is defective. A power supply supplies various voltages + - 5V, + - 12V ,etc. A power supply can be easily tested by a local shop with the proper test equipment. You might start there if you are a DIY! Short of that, you can purchase a power supply for under $65.00.
Nov 20, 2008 | E-Machines (T2824) PC Desktop
Emachines T2824 Dead System
if it is powering off like that it usually means that the mobo is bad, look at the capacitors on the mobo. if any of the tops are raised or corroding, it needs replaced. also if you see any part of the motherboard that is darker or orange, it is from a lot of heat, which means that parts may have gotten too hot and melted.
usually for an emachine, the mobo's are usually more than the unit is worth. best solutiong would be to get ready to invest in another unit
Jun 05, 2008 | E-Machines (T2824) PC Desktop
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
E-Machines (T2824) PC Desktop Logo
136 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
