Question about Samsung ML 2010 Laser Printer
Samsumg ML2010 Laser Printer intermittent print out of margin
Samsumg ML2010 Laser Printer intermittent printing out of margin. Is there any fix for this? It seems the electronics are bad, but I have no way of proving it. The drivers are fresh from Samsung download page.
    Scholar:
  • 136 Answers
Here;s what I would do, uninstall the Drivers, then re-install the drivers again, see if this improves it, if not you will need to call samsung, **** wish you were in Ct we are Authorized Samsang Dealers.
Sorry I think based on the rules of fixya.com I can't even give you Samsung's number to call for Tech Support, Hey their rules not MINE.
Posted on Mar 08, 2009
When printing a duplex booklet, the printout is reduced in size with larger margins than in original document. How can I get it to print regular size?
It happens when the documents is on A4 size and the printer is set to print on letter size (which is smaller in size). Hence the printer automatically resizes the prints which result in larger margins and print as compared to the actual document.
Therefore, when you print the documents (Press Ctrl+P) you have to select the paper (A4) from the print properties.
Hope it helps! Good Luck!
CreativeTECH
Mar 02, 2011 | Brother MFC-9840CDW Laser Printer
When I want double sided printing with samsung ml2010 printer, the online error stay red after one side is printed. Then i can do nothing but turn off the power button. it goes well when one sided...
I solved it!! Just hold down the Cancel button and I think it acts as the OK button. The red light will go away and turn green and it will print the odd pages. There you go!
Dec 18, 2010 | Samsung ML 2010 Laser Printer
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
Huge Margin with Kyocera FS 1000+
If the FS-1000 prints too far down the page or leave too much top margin or leaves a gap at the top of the page etc (<- for google searches). This is a problem with the felt pads on the three solenoids/clutch electro magnets that are under the right panel (2 under the engine/button board, 1 under the inner plastic cover, sometimes 4 in total on other kyocera printers). They get compressed over time meaning the metal leavers come into contact with the solenoid meaning they are released too slowly. Simply replace the felt pads with .5mm cardboard or another non-sticky non-metallic material. Too thick and it prints too far up the page.
Sep 28, 2008 | Kyocera Mita FS 1000+N Laser Printer
Margins want gone
full bleed, eh? that will be in the print settings issue..make the margins 'nil' and you might get lucky. that's usually a custom print job, by the way.
Feb 06, 2008 | Dell 3110cn Laser Printer
How can I print without margins?
You may all you need to do is open the properties of the printer and check that there maybe a setting that says margins or you are looking for edge to edge printing. Check that then you should be able to print without margins. Also within MS word click file then page setup and check the margins in that as that can also cause your fault.
Hope this works
Thanks J
Jan 08, 2008 | Samsung CLP 300 Laser Printer
Samsung ML 2010 Laser Printer Logo
165 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
