Question about Whirlpool Duet GHW9150P Front Load Washer
How do I get the hose off of my hose on duet front loading washer
How do I check for a clogged drain in my washer? Do I need to remove the back panel inorder to check the hose?
  • 6,784 Answers
Yes. you can check the hose but, most clogs originate deeper into the system beyond the back panel. its always good practice to remove the panel so that you can check thoroughly.
Posted on Mar 07, 2009
Not draining
take the bottom panel off and check and clean drain pump filter
Feb 27, 2014 | Whirlpool Duet WFW9150WW 4.0 Cu. Ft. Front...
I have a whirlpool duet front load washer. the spin cycle did not complete and their's water still left inside. i've tried to shut off the washer and restart it, it will spin once and then stop...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front loading machine stops before the final spin cycle, leaving loads full of water. Prior to stopping the display shows 18 to 22 minutes left in the cycle, but suddenly stops. There is no...
Hi
Daniel
Aug 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front load washing machine (Duet Sport) is Flashing a F-21 and F22 code and will not spin and drain.?????
The drain is clogged. remove the bottom kick panel. should be 3 or 4 1/4" nuts. open drain pump slowly. you may want to have a container to catch the water and some towels. check drain pump for foreign objects. also check the drain hose. make sure its not kinked or clogged. also check electrical connection to the pump.
if all the above have been checked and the unit still doesn't drain, then you may need to replace the drain pump
Mar 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wont drain water
remove the lower front panel, at the lower right side unscrew the drain pump screen(get some towels),clean screen and make sure pump inside is clean also, screw it back in and test washer.
good luck to you.
Feb 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport wont drain.....?
Remove any kinks in the drain hose. Ensure that the washer is not sitting on the hose.
Inspect the household drain. Remove clogs, if possible. Call a plumber if you cannot remove the clogs.
Check the drain and make sure there is an air gap between the hose and drain. An air gap is necessary to prevent the drain hose from siphoning water.
Clean the pump filter. Open the pump access door. Turn the pump filter counter-clockwise and remove it. Remove dirt and debris. Replace the filter and close the pump access door.
Rearrange the clothing in the load. An unbalanced load can prevent the washer from spinning or draining.
Allow the washer to cool down for two hours. If the washer overheats, it will stop the motor and cool down before restarting.
Close the door completely. The washer will not operate if the door is not securely closed.
I hope the above helps.
Good luck.
Jan 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Do you have to take the back off your front load washer to replace the drain hose
Your drain hose connects to a plastic elbow that sticks out of the back of the washer. No need to remove anything other than the clamp holding the drain hose to it. If you need a new elbow, Remove the top off the washer- 2 or 3 7mm screws on back edge of top, then slide top to rear of machine.
If it is the internal drain hose remove the access panel on bottom front and the top and try to do it from both places.
Jun 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F21 code and leaking from behind washer where hose comes out. Already used shop vac to drain hose, got code again on cleaning cycle.
F21 is a code for Long Drain.check to see if anything is clogging the pump.If you remove the 3 1/4" hex screws from the bottom panel,you can remove the panel.Behind the panel is a large white pump.You can remove the filter and check to see that nothing is clogged inside.
Apr 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9100LW1 getting f2 error. removed panel, filter, pump and hose not clog, ran diagnostic and came up with sud error
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
167 people viewed this question
Dan Webster
Dan Webster
Sal De
