My Inglis top loading washing machine is leaking. I would like to take the back off to see if I can find the problem....how do I do that?
  • jlauthor Mar 08, 2009
    Thanks
  • wsreay Apr 30, 2009
    My Inglis washer leaks also, But LOTS! I went to check on a load and there was two inches of water on the floor, and I don't think it's a hose. It' approximatly 20 years old, but has worked great until now. Help, anyone?
  • 40 Answers
Two screws at back bottom corners of control panel unscrew all the way but they should stay in then pull bottom of control panel just grab where screws are at same time and pull forward. then take a screw driver (flat head) there are two metal clips gold colored take them off by using screw driver and pusning forward on clips to release them then unplug door switch black plug three wires then lean cabinet forward and pull it off top front and sides will all come off then check for leaks
Posted on Mar 08, 2009
Get top of washing off inglis washing machine
I would get a quote off the inglis engineer as we don't carry service manuals on this site eric
Jan 07, 2018 | Washing Machines
Inglis washer
Plug off the wall mains. Remove the back / and or top. Plug in to test an empty wash, observe where the leaks comes from without touching anything - you may get shocked or injured. After you locate where the leak comes from your only have to tighten (of course after unplugging again). Spares if needed can be obtained by going to google - washer spares, with your brand/and or model number
Pl click if helped, thanks.
May 26, 2013 | Washing Machines
Whirlpool Inglis washer super capacity, 8 cycles, 2 speeds. Bought in May 2008. Works well and washes well, but it is VERY loud and seems to be getting louder and now there is a faint rubbery smell when it...
I received an Inglis Washing machine from soneone on freecycle. They thought the belt had broken, doesn't have a belt, it's gear driven. I'd bet the noise you hear is the coupling going out, (rubber). Good luck.
Jun 11, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Inglis dryer-spinning,not heating,Inglis washer not spinning well
Your heating element is going out. Mine did this a few months ago. It is an easy fix. Look up the part online.
Apr 13, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washer top load
The clicking is coming from a bad drive coupling:
Top loader repair tips
Feb 20, 2009 | Whirlpool Inglis IP4400 Washer
INGLIS WASHER SUPERB AGITATOR DOES NOT WORK
sorry not real solution as I am not familiar with that design but recommend replacing machine.
Jan 31, 2009 | Whirlpool Inglis IP4400 Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Inglis washer LO-38002
any appliance parts store. it should be a stocked item.
Jan 10, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
