Question about Insignia 37" LCD Flat-Panel HDTV
Red color appear on my Insigna TV
Hi! I have a problem with my Insigna 32' TV. Most of the time, there's red color appear on the screen when I watch tv or dvd. It's not really a line... it's everywhere like if I push spray paint.
I try to move the TV in another room. I also buy some better cable at Future Shop. Nothings seems to work. My warranty is over.
Could you please help me?
Manon Doucet
P.-S. -- Sorry about my English. I speak Freanch.
    President:
  • 814 Answers
This most likely a problem with the back lights and inverters circuits.The back lights may be receiving low voltages from the inverter circuit causing the led's not to function correctly. This needs to be tested by someone who can check the inverter circuits for correct voltage levels and the backlights for proper functioning.This usually has to be done in a service center.Try this website for Help and possible repair. LCDParts.net. Technical support telephone number is : 1-877-870-0581 or 1-415-682-8635 Hrs 9am to 5pm P.S.T. This site has lots of information on these type of problems. Hope this helps you with your problem.
Posted on May 13, 2009
55PW936317F appears to me to be to red
Turn the color off and or go to a black and white program--stand back and examine the screen--what color is screen with no color?
If red or pinkish you may be able to locate and slightly adjust the red screen control down to get rid of this.
It is not real easy on this set as the controls are inside the set and face the rear--two person job--one watches the screen and the other slowly turns (tiny bit at a time) the red screen down.
May 28, 2012 | Philips 55PP9401 55" Rear Projection...
I keep losing th red color on my screen, what is going on
Y sus problem with your TV. You need a basic tv knowledges to repair it yourselves. Regards
Feb 26, 2011 | Sansui 32" TV
While watching TV - I heard a slight click noise in the remote and the screen color immediately changed color to predominately green ( still see blues and yellow) but red spectrum is not working ?? I have...
U have all the tools and can u also do basic soldering?Tv might have cold sodering joints on the CRT video board socket that connected video board and the CRT tube together.Must take tv aparts and resolders all the CRT holes sockets of the video board.Also resolders the Yoke wires R,G,B connections to the main board too.Should solved this problems.U can't do this,than u must hire a tv Tech to do the repair,sorry.
Feb 25, 2011 | Toshiba 32A33 32" TV
Will not turn on, red light as off, when I push power the red light goes off but
Look for 2 pico fuses in the secondary section of the power supply. I'm sure one of them is blown, that is why the 24 volts are missing.
I will let you know the locations later when I get home.
Good Luck.
Jan 10, 2009 | Insignia 32" 720p Flat-Panel LCD HDTV
Proton pltv 32 no signal
I have the same problem. It seems the tv is switching from composite1 to composite 2 source.
Jul 09, 2008 | Protron PLTV-32 Television
Panasonic plasma hdtv with crazy red coloring
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Televison & Video
Ilo 42" Wide Screen LCD TV...Picture Malfunction
From some of the forum threads I've read about this, it seems like there were early issues due to bad firmware, but they have all be resolved with the recent updates. It also appears to be very easy to replace the hard drive. Just swap it out, format from the menu and you are done.
u will neeed to get it updated
Jan 25, 2008 | iLO 3200 32 in. LCD Television
Bad Color - Not much red
picture tube is goin bad............
Dec 28, 2007 | Sony KV-32S26 32" TV
Red distortion
it sounds like your IR board is going out, its easy to replace and is inexpensive usually about 10.00 plus tax and shipping, and very easy to install, its one of the few parts you can buy for these models outside of the 479.00 dollar control box.
Dec 11, 2007 | Polaroid FLM-3225 32 in. LCD Television
Picture color
have JVC AV-32F702 TV. It's picture color is very red. unable to adjust colors through menu. Channel numbers are also in red now instead of normal green. any suggestion? please check red color cathode circuit 1 check red output from ic to red cathode ckt 2 check voltage on r output ckt& ic or tr. 3 check loose contact in red cathode ckt 4 check crt base for loose. 5 loose connector 6 chroma ic thanks
Sep 09, 2007 | JVC AV-32F702 32" TV
Insignia 37" LCD Flat-Panel HDTV Logo
175 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
