Question about Maytag MAV7600 Top Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
Maytag Atlantis MAV7600AWQ Washer. Doesn't fill right away when starting the fill cycle. The water inlet valve has power and hums, but it takes about 3 minutes before it starts filling. At that point water is at full flow and the temperature is correct and the rest of the wash cycle works fine. Suspect inlet valve, but want expert opinion before replacing a $60 part.
  • judick Mar 08, 2009
    Screens are clean. Once water starts flowing the flow is normal.
  • 27 Answers
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Posted on Mar 07, 2009
The water is continually running in my maytag atlantis it seems like it has lost its ability to stop the fill process at the right time.
Try unplugging the machine then plug it back .. this may reset the electronics .. if not ... call a repairman.
Jul 02, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Won't start
if it filled proplerly and won't start now, it sounds like the door switch is broken, there could be something wrong with the rest of the electrical systems, however i would suggest the switch first. If there is a lot of noise like its trying to run, then its probably your transmission.
Jun 25, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a Maytag Atlantis MAV6200AWW. The washer
hi
the solenoid on the cold water is gone down or it is not fed with electric
Jan 29, 2018 | Maytag Atlantis MAV6451 Top Load Washer
Sits Pretty Doing Nothing,ARG!
Any codes on the front?. Try here to see if it's any help: Type in MAV6000 only
http://servicematters.com/maytag_library/html/index.html
Danwan
Sep 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis stopped mid cycle
Bad/worn/broken lid switch look at the back of the lid there is a little lid cam there that hits a switch,if this switch isn't engaging it will do just what you are describing.use a small screw driver to push the button in and see if it starts.
Sep 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Will not start wash cycle
Sound like the lid switch has went out , you should hear it click when the lid is close to an inch of being closed , they are un-expensive and easy to replace and they go out often from use. Easy to find online with your real model number located under the lid.
Phil
The washer with the grind noise is a main bearing going out and may be covered under warr. through maytag.
Apr 11, 2009 | Maytag Atlantis MAV7000
Maytag Atlantis MAV6200AWW Washer Problem?
I HAVE AN ATLANTIS MAYTAG WASHER . I HAD THE SAME PROBLEM AND I SOLVED AS FOLOLWS. REMOVED THE MOTOR, I APPLIED GENERAL PURPOSE GREASE ON BOTH SIDES OF THE SLIDING MOTOR SURFACE PLATE (MOTOR BASE) . THE GRASE HELPS THE MOTOR TO SLIDE BECAUSE AS YOU KNOW THE MOTOR DOES NOT HAVE ANY ADJUSTMENT. TRY IT PLEASE . GOOD LUCK
Feb 20, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis Washer, model MDG6200AWW
I just hooked up my washer and after filling it the motor hummed and smelt like it was starting to burn! Is this a fixable problem?
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Wash cycle will not start
you may have leaned on lid and damaged the lid switch , so the washer thinks the lid is open all the time unit will fill then stop with lid up.
Apr 13, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
371 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
